3 Replies Latest reply on May 9, 2013 3:25 PM by KirthivasanGanesan
    Image is not showing up on Dialog.
    KirthivasanGanesan
      Hi Guys
      I am getting problem with Dialog. In my Dialog I have created the image field which accepts image from dam by Drag and drop. Whil Iam dropping the image it is showing up inside the Dialog properly and is showing up on the screen also But when I try to edit the image the current image got vanished inside the dialog. I don't understand why it is happening?
      while uploading
      The above image is not showing up while editing. Could you please help me where I am doing wrong?
      here is my dialog.xml
                      <normalmode
                          jcr:primaryType="cq:Widget"
                          collapsed="{Boolean}false"
                          collapsible="{Boolean}false"
                          hidden="{Boolean}false"
                          title="Picture Properties"
                          xtype="dialogfieldset">
                          <items jcr:primaryType="cq:WidgetCollection">
                              <pictureurl
                                  allowUpload="{Boolean}true"
                                  autoUploadDelay="1"
                                  ddGroups="[media]"
                                  fieldLabel="Picture Link"
                                  fileNameParameter="./fileName"
                                  fileReferenceParameter="./fileReference"
                                  height="{Long}200"
                                  name="./file"
                                  requestSuffix="/image.img.png"
                                  rootpath="/etc/designs/aib/business/images"
                                  sizeLimit="100"
                                  uploadUrl="/tmp/upload_test/*"
                                  xtype="html5smartimage"/>
                              <picturealttext
                                  fieldLabel="Picture Alt Text"
                                  name="./picturealttext"
                                  xtype="textfield"/>
                              <picturetitletext
                                  fieldLabel="Picture Title Text"
                                  name="./picturetitletext"
                                  xtype="textfield"/>
                          </items>
                      </normalmode>
      Cheers
      Kirthi
        • 1. Re: Image is not showing up on Dialog.
          JitendraBansal Level 1
          Hi Kirthi,
          You need to create a hidden property in order to be able to edit the image. Create a node below your image node and set a hidden property. You can refer :
          /libs/foundation/components/textimage/dialog/items/tab3/items/resType
          e.g.
                              <resType
                                  ignoreData="{Boolean}true"
                                  name="./sling:resourceType"
                                  value="foundation/components/image"
                                  xtype="hidden"/>
                          </items>
          • 2. Re: Image is not showing up on Dialog.
            BearCherian
            We had something similar happen. I think we removed the property uploadUrl="/tmp/upload_test/*" to fix our issue.
            • 3. Re: Image is not showing up on Dialog.
              KirthivasanGanesan Level 1
              Hi Jitendra,
              It worked.Perfect. Thank you very much. I want to implement the same in my Custom widget which contains smartimage. But it is not showing up. Here is my Custom widget code for the smartfile but iam not getting Drag and drop jus it is showing up blank. Any idea how can I incorporate the smartfile in my Custom widget.
              // Picture URL
                                      this.add(new CQ.Ext.form.Label( {
                                          cls : "customwidget-label",
                                          text : ""
                                      this.bannerImageURL = new CQ.form.SmartFile( {
                                          cls : "customwidget-1",
                                          fieldLabel : "Picture Link: ",
                                          editable:false,
                                          allowBlank : false,
                                          anchor: '75%',
                                          maxLength : 100,
                                          cropParameter :"./image/imageCrop",
                                          ddGroups : "media",
                                          fileNameParameter : "./image/fileName",
                                          fileReferenceParameter : "./image/fileReference",
                                          mapParameter :"./image/imageMap",
                                          rotateParameter : "./image/imageRotate",
                                          requestSuffix : "/image.img.png",
                                          sizeLimit : "100",
                                          autoUploadDelay : "1",
                                          listeners : {
                                              change : {
                                                  scope : this,
                                                  fn : this.updateHidden
                                              dialogclose : {
                                                  scope : this,
                                      this.add(this.bannerImageURL);
              Once again thanks for helping me to resolve the issue. The above is another requirement. Any ideas?
              Cheers
              Kirthi
