4 Replies Latest reply on Jun 5, 2013 4:24 AM by AMULI
    Loading multiple data from a XML file?
    Rafael Carignato
      I'm having trouble loading multiple data from the same XML file. In this XML file I have a list of dishes I want to add into a menu. So, how can I load multiple data from different branches of the XML file into my text fields?
      Thanks in advance,
      Rafael Carignato
        • 1. Re: Loading multiple data from a XML file?
          shadowfax007 Level 1
          I'm not quite sure what you are trying to do.  I have this working with a .JSON file that loads "multiple" date into "multiple" fields in Edge - Is that what you mean?
          Here's an example:
          $.getJSON('slides.json', function(data) {
                    for(var i=0;  i<data.length;  i++)
                                        var s = sym.createChildSymbol("slide", "stage");
                                        s.$("photo").css({"background-image":"url('"+data[i].image+"')"});
                                        s.$("title").html(data[i].title);
                                        s.$("price").html(data[i].price);
                                        s.getSymbolElement().css({"position":"absolute",
                                                            "left": i*225+50+"px",
                                                            "top":"100px"});
          Each name above (photo, title, price) has an element on the stage (or in my case, a symbol) and my .JSON file has has a "branch" for each of these:
          "image" : "images/7783.jpg",
          "title" : "SNOCONUTS",
          "price" : "12.00"
          Hope that helps...
          James
          • 2. Re: Loading multiple data from a XML file?
            AMULI Level 4
            Thank you James,
            I was planning to make a generic slideshow from XML data. This is well-timed and very helpful.
            Having an AS3 background, I was wondering about asynchronous programming. This getJSON method looks like the equivalent of an Event.COMPLETE event handler.
            What about the equivalent of an IOErrorEvent.IO_ERROR event handler ? Thanks,
            Gil
            • 3. Re: Loading multiple data from a XML file?
              Rafael Carignato Level 1
              Found a way to do it. I created X text elements named "textbox1", "textbox2", etc. Here's the code:
              var i = 1;
              var message;
                      $.ajax({
                              type: "GET",
                              url: "books.xml",
                              dataType: "xml",
                              success: function (xml) {
                                  $(xml).find('Book').each(function () {
                                      var sTitle = $(this).find('Title').text();
                                      var sAuthor = $(this).find('Author').text();
                                      var sGenre = $(this).find('Genre').text();
                                      message = sTitle + ", " + sAuthor + ", " + sGenre;
                                      console.log("Message: " + message);
                                      console.log("i :" + i);
                                      sym.$("textbox" + i).html(message);
                                      console.log("");
                                      i++;
              • 4. Re: Loading multiple data from a XML file?
                AMULI Level 4
                Thank you Rafael,
                Being much more comfortable with XML, I will follow your example for the slideshow.
                I just bought the book Learning jQuery (Packt Pub). Skimming through, I saw code similar to yours in chapter 6 (Sending Data with Ajax). After reading it, I will possibly complete the thread about error handling.
                Gil
