6 Replies Latest reply on May 9, 2013 12:18 PM by DaveVFS
    How can I get the title's default aspect ratio to be 100% instead of 145.3% Premiere CS4
    DaveVFS
      I have an annoying, nagging titling problem in Premiere CS4.
      I can select any default style.  Fine.  I click to put the text in the titler, that's fine.  Then it always, EVERY SINGLE TIME, has the text start out at 145.3% Aspect.  It's always wide text when I start, no matter what the default looks like in the style picker.  Unfortunately, for every project I'm on, normal text is desired so any time I ever want to use the CS4 titler, it takes a click or two more than necessary to get it back to 100% aspect.
      Over time it is REALLY annoying when it could just be set to the default of 100 somehow.  I hope.
      How can I get the title's default aspect ratio to be 100% instead of 145.3%?  I could be a lot happier if I found out the answer to this!  Thanks.
