3 Replies Latest reply on Aug 2, 2006 4:26 PM by Newsgroup_User
    Major JFSL Bug with addNewText
    StevenBlitz Level 1
      If I make a JSFL file with this in it and run it using Run Command..., it works:
      fl.getDocumentDOM().addNewText({left:10, top:10, right: 100, bottom:30}); fl.getDocumentDOM().setTextString("Hello World");
      If I make a WindowSWF panel with the same thing in it, wrapped in MMExecute, it doesn't:
      MMExecute("fl.getDocumentDOM().addNewText({left:10 , top:10, right: 100, bottom:30})"); MMExecute("fl.getDocumentDOM().setTextString(\"Hel lo World\")");
      It will addNewRectangle, it will addNewOval, etc. It WILL NOT addNewText no matter what I do, no matter how many ways I tried it.
      This looks totally broken to me. Can anyone verify it?
        • 1. Re: Major JFSL Bug with addNewText
          Level 7
          StevenBlitz,
          > wrapped in MMExecute, it doesn't [work]:
          > MMExecute("fl.getDocumentDOM().addNewText({left:10,
          > World\")");
          Works for me, bro. I hate using MMExecute, because it's always so
          tedious to format the strings -- but this works just fine for me.
          I get the text.
          David Stiller
          Adobe Community Expert
          Dev blog, http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: Major JFSL Bug with addNewText
            StevenBlitz Level 1
            I figured it out, too.
            You must have the panel docked. If the panel isn't docked and is free floating, addNewText doesn't work.
            That's a bug no matter how you cut it.
            • 3. Re: Major JFSL Bug with addNewText
              Level 7
              StevenBlitz.
              > work.
              I hate to sound disagreeable, but I have to disagree. That's not it.
              ;) It works in both cases.
              It's *seems* like a bug, I agree, but I believe what has happened here
              is that you haven't grasped how WindowSWF content works. When you go to
              Window > Other Panels > [name of custom WindowSWF], you load the SWF in
              question into memory. When it is first loaded into memory, the MMexecute()
              content in that SWF's timeline runs -- once. If you close that window again
              and open it in a single sitting (one "session," as it were), you're not
              actually reloading it, but only showing and hiding it. Make sense?
              If you trigger that MMexecute() content with a button, it'll work every
              time -- docked or undocked.
              David Stiller
