9 Replies Latest reply on May 10, 2013 10:49 AM by Ann Bens
    Exported for YouTube - uploaded results not up to par
    sbg59
      I've exported media using recommended YouTube settings, Match Sequence Settings, and a tweaked ton of other parameters (bitrate, smaller aspect ratios, etc), but YouTube's processing still results in jittery video with dropped or repeated frames.  I've seen some really good quality videos from others - what am I missing?  Now granted - these videos have a lot of movement, containing pans, tilts and zooms throughout, so I know I'm asking a lot from YouTube.
      The raw footage was acquired on JVC GY-HD100U at 720p.
      I have 2 samples on YouTube:
      1. PP CS6 Export Settings: YouTube 720p 29.97 fps    -   http://youtu.be/tSvWUtYgBBU
      2. PP CS6 Export Settings: Match Sequence Settings  -     http://youtu.be/n9iX69l7lNM
      Another question:  Any suggestions for high quality video hosting?
      Thx!
        • 1. Re: Exported for YouTube - uploaded results not up to par
          Jim_Simon Level 8
          You've set the videos to Private, which means only YouTube accounts can watch them.  You need to change them to Unlisted.
          • 2. Re: Exported for YouTube - uploaded results not up to par
            sbg59 Level 1
            changed to "unlisted"...  duh.
            • 3. Re: Exported for YouTube - uploaded results not up to par
              Stephen_Spider Level 3
              It's youtube's fault. Try sending a higher bitrate mp4, that may help a bit. May not.
              • 4. Re: Exported for YouTube - uploaded results not up to par
                sbg59 Level 1
                Yeah, I tried 7.5k, 10k, then 12.5, 15 and finally maxed it out.  got worse and worse actually...    thx for suggestion, worth a try.
                • 5. Re: Exported for YouTube - uploaded results not up to par
                  Jim_Simon Level 8
                  Were they shot at the oddball 720p/30 or the standard 720p/60?  Do they also look like this on the computer, or just on YouTube?
                  • 6. Re: Exported for YouTube - uploaded results not up to par
                    sbg59 Level 1
                    Ah-ha!  I'll bet that little change in acquisition would help, wouldn't it!  It's 29.97 fps - all other specs for original media and edited media are listed below as well.  THX, well worth looking into!!!
                    To answer your 2nd question, though, they playback perfectly on my machine.  And incidentally, Vimeo does a much better job than YouTube - with this clip, anyway...
                    ORIGINAL MEDIA General Information
                    Format                                : MPEG-4
                    Commercial name              : XDCAM EX 35
                    Format profile                    : Base Media / Version 2
                    Codec ID                            : mp42
                    Overall bit rate mode       : Variable
                    Overall bit rate                   : 35.6 Mbps
                    Video
                    Format                                   : MPEG Video
                    Format version                        : Version 2
                    Format profile                        : Main@High
                    Format settings, BVOP            : Yes
                    Format settings, Matrix           : Custom
                    Format settings, GOP              : M=3, N=15
                    Codec ID                                 : 61
                    Duration                                 : 1mn 25s
                    Bit rate mode                          : Variable
                    Bit rate                                 : 34.0 Mbps
                    Maximum bit rate                : 35.0 Mbps
                    Width                                    : 1 280 pixels
                    Height                                   : 720 pixels
                    Display aspect ratio               : 16:9
                    Frame rate mode                   : Constant
                    Frame rate                             : 29.970 fps
                    Color space                            : YUV
                    Chroma subsampling             : 4:2:0
                    Bit depth                                : 8 bits
                    Scan type                                : Progressive
                    Compression mode                 : Lossy
                    Bits/(Pixel*Frame)                  : 1.231
                    Time code of first frame            : 01:28:46:00
                    Time code source                     : Group of pictures header
                    Stream size                              : 345 MiB (96%)
                    Color primaries                          : BT.709
                    Transfer characteristics                 : BT.709
                    Matrix coefficients                      : BT.709
                    EDITED MEDIA General Information
                    Format                               : MPEG-4
                    Codec ID                             : mp42
                    File size                              : 200 MiB
                    Duration                               : 5mn 15s
                    Overall bit rate                     : 5 319 Kbps
                    Video
                    Format                                 : AVC
                    Format/Info                         : Advanced Video Codec
                    Format profile                        : High@L3.1
                    Format settings, CABAC       : Yes
                    Format settings, ReFrames    : 3 frames
                    Format settings, GOP           : M=3, N=90
                    Codec ID                               : avc1
                    Codec ID/Info                      : Advanced Video Coding
                    Duration                               : 5mn 15s
                    Source duration                     : 5mn 15s
                    Bit rate                                 : 4 994 Kbps
                    Height                                   : 720 pixels
                    Frame rate mode                     : Variable
                    Minimum frame rate               : 29.970 fps
                    Maximum frame rate             : 30.000 fps
                    Standard                                 : NTSC
                    Color space                              : YUV
                    Bit depth                                : 8 bits
                    Bits/(Pixel*Frame)                       : 0.181
                    Stream size                              : 188 MiB (94%)
                    Source stream size                       : 188 MiB (94%)
                    Language                                 : English
                    Encoded date                             : UTC 2013-05-08 21:03:21
                    Tagged date                              : UTC 2013-05-08 21:03:21
                    mdhd_Duration                            : 315248
                    • 7. Re: Exported for YouTube - uploaded results not up to par
                      Jim_Simon Level 8
                      OK, what are your sequence and export settings?
                      • 8. Re: Exported for YouTube - uploaded results not up to par
                        sbg59 Level 1
                        Sequence settings should match original as soon as I dropped first clip in - correct?  If not, I have the project up now, where would I find that info?
                        Export:
                        Best results were with both
                        1> Match Sequence settings
                        2>PP's included setting of H.264/YouTube/720p 29.97
                        • 9. Re: Exported for YouTube - uploaded results not up to par
                          Its a YT thing. Upload again.
                          I have uploaded movies more than once to get it right.
                          I only use a PPro YT preset.
