0 Replies Latest reply on May 10, 2013 9:22 AM by diane_xml
    How do I update a text field by assigning an hyperlink with loadXML in ES4?
    diane_xml
      I am using a dropdown list to select a court location.
      When the location is selected,
      the address field and the phoneNo field are updated according to the location selected.
      I have tried in vain to get the website field populated with a rich text hyperlink.
      I tried to save the rich text in a variable, but ES4 gives me an error for the escaped quotes (\")
      var sLoc = "Abbotsford";
      var oLink = "<body xmlns=\"http://www.w3.org/1999/xhtml\" xmlns:xfa=\"http://www.xfa.org/schema/xfa-data/1.0/\"><p style=\"letter-spacing:0in\"><a href=\"http://www.provincialcourt.bc.ca/court-location/" + sLoc + "\" style=\"margin-top:0pt;margin-bottom:0pt;text-valign:bottom;font-family:'Helvetica';font-size:8p t\">" + sLoc + "</a></p></body>";
      courtWebsite.value.exData.loadXML (oLink, false, true);
      When I change the escape quotes to single quotes, I don't get an error but:
      1. the PDF preview shows that the update does not work ; and
      2. when I return to the XML view,  the variable is empty where the rich text content used to be. (var oLink = "") and the content of the oLink variable is now a child of the <script> element of the event.
      BTW, it does not resolve the content of sLoc; so replaced sLoc within oLink with the actual content... same problem.
