1 Reply Latest reply: May 13, 2013 2:25 AM by lesavage RSS
    Why can't I get the installs completed?
    Ronald Chambers Community Member
      I have PSCS6x in Cloud.  I've selected a couple of PS panels to install.  They download fine then the spinning wheel goes on forever and when I move the mouse from the Exchange panel, everything stops as far as the downloading etc.
      Install never completes.
      Also why doesn't using Extension manager have same options so I don't waste time in PS?  What shows in Extension Manager and Exchange Panel don't agree either.  Nothing the same.
      I am on two PCs and have same items installed on both.
      New Exchange Panel is worthless now in my opinion.
      RONC
        • 1. Re: Why can't I get the installs completed?
          lesavage Adobe Employee
          Hi Ronald,
          In order to help, it would be great if you could provide the following information:
          Windows platform
          Photoshop Version
          Extension Manager version
          Have you installed the latest CSXS Infrastructure update? Alternatively, complete the following steps:http://helpx.adobe.com/creative-cloud/kb/unable-sign-applying-csxs-patch.html
          Could you complete the steps again with the following logging applied:
          Edit the StartupOptions.xml file in CS6ServiceManager
          • Mac OS X: /Library/Application Support/Adobe/CS6ServiceManager/configuration
          • Win: C:\Program Files\Common Files\Adobe\CS6ServiceManager\configuration
          In the StartupOptions.xml file add to the element systemProperties
          <vcentry key="loglevel"> <vcint>6</vcint> </vcentry>
          Could you also try generating the Extension Manager logs as outlined:http://forums.adobe.com/message/4275082#4275082
          Could you send the following log files to me at lesavage at adobe dot com
          C:\Documents and Settings\<user>\AppData\Roaming\Adobe\Exchange\AdobeExchange.log
          C:\Documents and Settings\<user>\AppData\Local Settings\Temp\PDApp.log
          C:\Documents and Settings\<user>\AppData\Roaming\Adobe\CS6ServiceManager\logs\Vulcan.log
          Thanks in advance,
          Lea
