18 Replies Latest reply on Jul 13, 2014 2:16 AM by Franzstadt
    Codec "xdvc"
    ThommyB
      Dear Forum
      i´m very confused about importing .mov files into a premiere pro project.
      I got a couple of mov-files to work with in premiere pro.
      I read in varios threads about the difficulties with these files, but I was not able to solve my problem.
      I am using Premiere Pro CS5 on a Windows computer 64-bit system.
      I figured out that the mov-files requires the "xdvc"-codec. So far so good. But my question now is: Where can I get this codec to work with these files in Premiere Pro? What are the nex steps to solve my problem?
      Thank you very much in advance!!
      Best Regards
      Thommy
      With MediaInfo I become these information about the mov-files:
      Video
      Format :MPEG Video
      Commercial name :XDCAM EX 35
      Format version :Version 2
      Format profile :Main@High
      Format settings, BVOP :Yes
      Format settings, Matrix :Custom
      Format settings, GOP :M=3, N=12
      Codec ID :xdvc
      Duration :2mn 24s
      Bit rate mode :Variable
      Bit rate :35.0 Mbps
      Width :1 888 pixels
      Original width :1 920 pixels
      Height :1 062 pixels
      Original height :1 080 pixels
      Display aspect ratio :16:9
      Frame rate mode :Constant
      Frame rate :25.000 fps
      Standard :Component
      Color space :YUV
      Chroma subsampling :4:2:0
      Bit depth :8 bits
      Scan type :Interlaced
      Scan order :Top Field First
      Compression mode :Lossy
      Bits/(Pixel*Frame) :0.698
      Stream size :596 MiB (96%)
      Title :Apple Video Mediensteuerung / Apple Alias-Datensteuerung
      Language :English
      Encoded date :UTC 2012-08-05 20:39:31
      Tagged date :UTC 2012-08-05 20:39:59
      Color primaries :BT.709
      Transfer characteristics :BT.709
      Matrix coefficients :BT.709
