1 Reply Latest reply on May 11, 2013 12:41 PM by Peter Spier
    Fitting text to "curved pie shape"
    RobPOzzy
      I want to achieve an effect as if text is filling the segments of a dartboard.  So the text path would be curved and fill the segment running towards the centre.  If you picture the black 20 segement of a dartboard the text should fit that shape but follow the curve. The image shows the sort of effect I want....  Ideally each section should contain the "paragraph" of text rather than it running as if around the grooves of a record.
      I am using InDesign CS6
      I know how to fill a shape in InDesign.  However the text would be in straight lines rather than following the curves of the pie shape.
      Does anyone know if what I want is possible with InDesign and how.  If it is not, what is the way to do it on, say Illustrator?
      Thank you for any help!
