1. Re: code navigator cs6 fails to open
Sudarshan Thiagarajan May 11, 2013 10:54 PM (in response to William Noel)Are your CSS files locally present on your computer or are they on a remote server?
Can you try clearing your cache to see if it helps? http://forums.adobe.com/thread/494811
2. Re: code navigator cs6 fails to open
William Noel May 12, 2013 2:51 PM (in response to Sudarshan Thiagarajan)Yes - all CSS files are local
3. Re: code navigator cs6 fails to open
William Noel May 12, 2013 3:20 PM (in response to Sudarshan Thiagarajan)Could it be a conflict with DW versions?
I have CS4, CS5.5, and CS6 on my computer - should I uninstall the older versions?
A serach for .dat or MacFileCache shows up in only in the CS4 folder
4. Re: code navigator cs6 fails to open
William Noel May 13, 2013 7:27 AM (in response to Sudarshan Thiagarajan)Thanks Sudarshan,
Code Navigator works the first 3 or 4 times then it stops working.
I uninstalled CS4 but it didn't seem to make any difference.
- since I'm using CS6 now can I uninstall 5.5 also?
5. Re: code navigator cs6 fails to open
Sudarshan Thiagarajan May 13, 2013 9:38 PM (in response to William Noel)WillzShireDDC wrote:
Thanks Sudarshan,
No, that wont make any difference. You can run multiple versions of CS on 1 computer.
Can you go to Site > Advanced > Recreate Site Cache to see if it helps? Also, go to Help > Updates to ensure you have all updates installed.
