3 Replies Latest reply on Oct 20, 2007 9:46 PM by kglad
    Distance Calculation - from Isometric view
    gregmax17 Level 1
      I need a lot of help with this one. I uploaded an image so you can see what I am talking about because I know this will help explain what I am trying to do.
      I made an isometric world and am trying to calculate the distance from the center to the outter edge of the circle (or map). The red dot in the middle is the middle. Looking at the image its obvious that the green line is longer than the blue line, yet BECAUSE its an isometric world, the distance is exactly the same. Right? So here is the real problem: How do I calculate, or determine, the distance of the orange dots from within red dot in the middle? I know it isn't using the a^2 + b^2 = c^2 method - because that doesn't relate to isometric stuff. My guess is some how using angles, but I have had no luck :(.
      What do you guys suggest, and can you provide some small snippets to help me? Many thank yous
      *Here is the example picture: http://www.gmajr.com/example.jpg
