2 Replies Latest reply on May 12, 2013 7:09 AM by JJMack
    Paths
    Lyndon 49
      When I create a path in CS6 and then go to fill selection with foreground colour it leaves the path unfilled but fills the rest of the document, as if inverted, I do have subtract front shape selected, how do I overcome this so that only the selected path fills.
        • 1. Re: Paths
          conroy Level 5
          Eh?
          Are you serious?
          You make a point of stating that you are using "Subtract Front Shape" but want the inverse result of what it is correctly producing.
          Try the alternative combining-modes!
          • 2. Re: Paths
            A path is not a selection but you can change a path into a selection and fill the selection.  There is even an icon in the bottom of the paths palette that you can use to make a selection for the path.
            What you filled may have been a layer or some other target that fill you used was for. Again a Path is not a selection.
