I wrote about this problem before and did not get a satisfactory answer! On approximately 5-3 I had new adobe upgrades installed and every since that upgrade I have been getting all types of pop-ups and I keep getting a note on the bottom of the screen that constantly says "this webpage wants to run the following add-on: Adobe Flash Player from Adobe Systems Incorporated. The reply I received was you have "malware on your computer"! I just ran a scan of my computer and it DID NOT find any malware on my system! I have pop-up blocker turned on, but whatever happened when the upgrade loaded it does not make any difference, as I still get the pop-ups and the message at the bottom of my screen! Other than uninstalling Adobe and re-installing it I do not see a solution unless you have a better suggestion! Thank you!
that's an ie security setting. check with ms to see if you can turn it off.
