• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
CFMX 6.1's Virtual Memory Use problem!!
New Here ,
Jul 07, 2006 Jul 07, 2006
I appologise for the long post in advance...
Ok... so I have this script that, using cfdirectory, will check a directory for any files that may have been uploaded, if there are files, it loops through the results and reads the files one at a time, line by line, using the FileReader.cfc (Uses the Java FileInputStream, InputStreamReader, and BufferedReader to provide a way to incrementally read large files). The files are just pipe "|" delimited data, each line represents a record for a db table.
Now as it's reading each line, it will perform some basic string parsing to clean up the file line to make sure the data is valid, blah blah blah and then it will write that "cleaned" line to another file using FileWriter.cfc (Java component once again). Once it's completely done reading the original file, it will close it and it will open the new "cleaned" version of the file, read it (FileReader.cfc), create an INSERT statement and then update the database table.
Now... this all works GREAT... until it has to loop through more than a few files... 3 - 4 files are NO problem! works like a charm, but throw 6 - 8 files at it and it dies, not a timeout mind you but an actual "java.lang.OutOfMemoryError" (now, I've tried making all the files exactly the same (just changed the name) and the weird thing is, it takes longer and longer to process each as it goes through the loop... I have the script write some stats as it's looping:
FILE 1 STATS
Status: Import Successfull
Line Count: 32,971
Processing Time: 74,237ms
FILE 2 STATS
Line Count: 32,971
Processing Time: 82,018ms
FILE 3 STATS
Line Count: 32,971
Processing Time: 94,476ms
FILE 4 STATS
Line Count: 32,971
Processing Time: 145,108ms
I know what you guy are probably thinking; "Woah man... CF isn't really meant to do that kind of processing...", I know, trust me I know... however, I really neeeeeed it too lol.
Ok, so as the script is running, I watch the Virtual Memory use of jrun.exe, processing say 3 - 4 of these files brings up the usage to approx 300,000k which yes, is a LOT but that's fine... this process is meant to run at night via a Scheduled Task...
When I run more than 4 files, things start to get ugly, keep in mind that these are EXACTLY the same files just re-named differently. The script will start lagging BIG time and on the last file (usually the last file) I'll see the memory usage spike from 350,000K all the way up to 600,000K and that's when it throws the "java.lang.OutOfMemoryError" and dies... I've tried commenting out the part of the script that updates the db, but still get the same problem...
So... what gives? How come CF Server does this??? I mean, it runs fine for the first few files... and then WAM, it dies... sorry for the long post... any insight here is VERY much appreciated... it would be AWESOME if the wonderful folks at Adobe could shed some light on this for me : )
CFMX 6.1 version: 6,1,0,83762
Windows XP Pro SP2
Intel P4 2.8Ghz
1Gb of Ram
TOPICS
Advanced techniques
Views
276
Translate
Translate
Report
Report
Community guidelines
community guidelines
New Here ,
Jul 11, 2006 Jul 11, 2006
up
Votes
Translate
Translate
Report
Report
Participant ,
300M memory usage while using "incremental" file reader?? Looks like it is "incremental" only in the sense that it increments memory usage. Did you try non-Java C/C++ file reader tags?
Votes
Translate
Translate
Report
Report
New Here ,
Jul 13, 2006 Jul 13, 2006
LATEST
quote:
Well I did try cffile originally... and it didn't even run... lol
Votes
Translate
Translate
Report
Report
Resources
Documentation
