• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Trouble with bullets
Participant ,
May 14, 2013 May 14, 2013
Often I find that bullets need to be the last thing I do in formatting content in my projects. It seems that if you bullet items before your done adding links or drop downs, those links and drop downs have a tendency not to work. Remove the bullets and then all those bells and whistles work again. Adding the bullets back at that point seems to be a standard practice for me now or a troubleshooting tactic when content misbehaves. If I am getting really frustrated because I can't add some DHTML drop down or make an image map that pops at a specific size and location... I take out the bullets.
Is this a bug? I never had to do this with other programs that format text and that can add bullets.
EXAMPLE:
Because of the bullets in the content below I could not image map the menu bar in the attached image and have a picture appear in a sized pop-up box showing the underneath contents should the operator pick it. Like the first menu item SETTINGS should show this but doesn't till I remove the bullets:
Settings200.jpgUntitled-1.jpgThe red squares are where I put the image maps for the user to further explore the software without having the software.
INSTRUMENT INTERFACE -
The Instrument Interface is where the user directs the Tracker to measure. Instrument-Interface4.jpg
The user wishing to bring in an instrument to a job file uses Instrument>Add on the menu bar. The operator has a few options available when adding the instrument:
  • Automated - SA automatically chooses the correct instrument and it's parameter settings to add from previous times opened,
  • Manual - The user is directed to select the proper instrument from a list and then run the Instrument Interface.
  • Simulated - In order to get some screen shot images or run an accuracy test without a real instrument connected, the user can operate the software, simulating a connected instrument
Views
710
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
I have moved this thread as it relates to topic production rather than the output.
When you create the link from the image you simply select a topic. Are you saying that if the target topic contains bullets, the link does not work? Sorry but I am struggling a bit to follow, not least because of the large font that means scrolling up and down to read the problem.
@petergrainge
Votes
Translate
Translate
Report
Report
Participant ,
May 15, 2013 May 15, 2013
Sorry about the font.
I am not sure why it happens, sometimes it appears that if the bullets are part of the content containing the image map I have a problem linking with custome sized pop ups, other times if the pop up is text and contains bullets some other oddity happens. It is only after I remove bullets fix my maps or text and then re bullet that things work properly.
Votes
Translate
Translate
Report
Report
Community Expert ,
You mean if the image map is in a list, correct?
If yes, then create an indented style so that the image is in line with the list items but in fact it is not.
If not, add a screenshot showing that shows more of the page.
What version of Rh? (Always include that in new threads)
@petergrainge
Votes
Translate
Translate
Report
Report
Participant ,
Sometimes the image is in a list, if it is though, the bullet is deleted for it. I never bullet images. I never indent images either, just center justify or place in a table cell to help with locating it next to text. The above example has a center justified image and image map (linked to user specified sized pop-up images) inside a paragraph that contains a bulleted list. The large image contains the image map and the small image is one of the pop-ups.
Votes
Translate
Translate
Report
Report
Community Expert ,
Is this a project that was originally created in Rh7 or earlier?
Rh8 changed to XHTML which is stricter. I am wondering if things would be better if you went to Tools > Options and checked the setting Convert to ... HTML.
Try that anyway.
@petergrainge
Votes
Translate
Translate
Report
Report
Participant ,
No I have always used 9 in the TCS3.5. Just checked that setting and it is set to convert to HTML.
Votes
Translate
Translate
Report
Report
Community Expert ,
May 21, 2013 May 21, 2013
LATEST
If you can recreate this in a new demo project and send it to me with step by step instructions on how to create the problem, I will take a look. From what you have described, I cannot see why this is happening.
@petergrainge
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
