1 Reply Latest reply on May 15, 2013 9:00 AM by JADarnell
    (Acrobat XI) Using Javascript to scan PDF text
    JADarnell
      I am scanning text in a PDF and reading it into memory using doc::getPageNthWord().  Reading the text from the file using the mark 1 mod 0 eyeball looks like this:
      References
      Greenpeace. 2012. Safeway charts new course for
        sustainable tuna. www.greenpeace.org/usa/en/media-
        center/news-releases/Travis-Nichols.
      Monterey Bay Aquarium. 2012a. Wild seafood issue:
         Overfishing, www.montereybayaquarium.org/cr/cr_
         seafoodwatch/issues/wildseafood_overfishing.aspx.
      (Please note that I am unable to determine how the PDF is causing the indent.  I am using three spaces, but a hex editor...well read on, please).
      Using the above function (i.e getPageNthWord()) the information comes in like   this:
      Wild
      seafood
      issue:
      • Ł Ł • • Ł Ł • • Ł Ł • • Ł Ł •
      www.
      Copying it to a text editor using the clipboard, it looks like this:
      "Wild seafood issue:"
      ", OOHJDO              AVKLQJ.
      Can anyone suggest a possible solution to getting the text in a readable format?
      TIA!
      John
        • 1. Re: (Acrobat XI) Using Javascript to scan PDF text
          JADarnell Level 1
          I have some additional information.  When I copy the text to a programming editor I see the latter transformation.  When I compare the text, letter for letter, each letter in the cryptic version  has been reduced in value by 29 with a few exceptions; periods and forward slants do not seem to have been affected.  Additionally, the letters f and i, when placed together, are interpreted as a single letter with an ascii version of 195.
          I have looked at possible XOR/OR bit fiddling conversions, but have not been able to figure out what is causing the transformation (or causing the transformation to fail).
