3 Replies Latest reply on May 14, 2013 10:07 AM by Lucia Lao
    Alignment tool
    karri.blake@pgn.com
      Is there and alignment tool? Where is it?
        • 1. Re: Alignment tool
          Lucia Lao Employee Moderator
            For text alignment, you should be able to find it on the Toolbar in Design tab - Open the form, make sure you are in Design tab.
          Select the text and then  the option circled here:
          If you are asking for a alignment tool for the actual form fields (when say they are side by side) then we don't have a tool, you will have to play around by resizing the width of each field.
          Hope this helps,
          Lucia
          • 2. Re: Alignment tool
            karri.blake@pgn.com Level 1
            Sorry, I should have been more clear. I have a text field and a picture field, although I can select both fields there is no option to align the two.
            • 3. Re: Alignment tool
              Sorry, we don't have a tool for fields alignment. In your particular case, you would need to align the text in the text field, and adjust the size of the image (or maybe create - enlarge or reduce - the image to fit well within the page or location) - please take a look at some of the Templates, some of the images are used as section header/footer or separators.
              If you like please, vote or add this feature to : http://forums.adobe.com/community/formscentral?view=idea
              If you need to add a new idea click "Create an idea" under "Actions" in the top right.
              Lucia
