1 Reply Latest reply on May 14, 2013 11:24 AM by adobescrname
    How can I set droppable to accept multiple draggable items?
    adobescrname
      I have five draggable items and a single droppable item (zena_sym) on the stage. I'd like zena_sym to accept three of those five draggable items and run a function when it does.  The problem I'm having is that I can only set it to accept one item at a time. Here is the code I'm using:
      //load jquery
      yepnope({nope:['jquery-ui-1.10.3.custom.min.js'], complete:init});
      //set counter
      sym.setParameter("counter", 0);
      //create semafor variable
      var semafor = sym.composition.getStage().getParameter("counter");
      //define init
      function init(){
      //define draggable items
      sym.$("majica_sym").draggable();
      sym.$("suknja_sym").draggable();
      sym.$("haljina_sym").draggable();
      sym.$("sesir_sym").draggable();
      sym.$("hlace_1_sym").draggable();
      //define zena_sym as droppable and also items it accepts
      sym.$("zena_sym").droppable(
      {accept: (sym.$("majica_sym") , sym.$("suknja_sym") , sym.$("sesir_sym"))},
      //define event and function
      {drop: function() {
      semafor = semafor + 1;
      sym.$("brpredmeta_txt").html(semafor);}
      Thank you for your help.
        • 1. Re: How can I set droppable to accept multiple draggable items?
          adobescrname Level 1
          Found it!
          So if you want to have a simple drag and drop application/game where you want to count only the right items (so some get accepted by droppable and some don't), you need to use the scope option (not accept). The scope option has to be the same for droppable and draggables it accepts. Here is the code that worked:
          //load jquery
          //set counter
          //create variable to count the number of "right" drops
          //define function init()
          function init(){
          //define draggable items and set scope to items that get accepted by droppable
          sym.$("majica_sym").draggable({scope:"gear"});
          sym.$("suknja_sym").draggable({scope:"gear"});
          sym.$("sesir_sym").draggable({scope:"gear"});
          //define droppable and the scope it accepts
          {scope:"gear"},
          //define what happens when an item is dropped
          {drop: function() {
          sym.getComposition().getStage().$("brpredmeta_txt").html(semafor);}
