1 Reply Latest reply: May 14, 2013 2:04 PM by Reviewer1066 RSS
    XRef idref attribute not recognized upon opening of XML file
    mattrsullivan CommunityMVP
      ***I suspect this might be an XSL-related solution***
      I've inherited a client's xml structapp that goes out to XML quite nicely, but doesn't read in the requisite idref upon opening in FM11.
      The read/write rules are fairly straightforward:
      element "xref"
        is fm cross-reference element "XRef";
        attribute "xrefstyle" is fm property cross-reference format;
        attribute "linkend"           is fm property cross-reference id;
      However, the linkend attribute is not populated upon opening, nor is the value (which is present in the XML file) passed as the cross-ref id into FM.
      Anyone have a solution?
      Could this be a result of XSL parsing, and might the XSL be dropping the attribute upon import prior to application of the RWR? I haven't dug into the import XSL yet, but suspect that's where I need to go.
      -Matt
