22 Replies Latest reply on May 21, 2008 11:23 PM by DHMerritt
    Publishing to Word
    DHMerritt Level 1
      Good Day All
      I know that this questions might have been asked a 100 times over and I tried to go through the forum using the search funtionality but I have not found much except that this is a bug, but I am hoping that I missed a response and that there is a fix or a "work-around" to the problem.
      My problem is that I want to publish my captivate to a word doc but I get this error message:
      "An error was encountered while publishing to Word.
      Please check to make sure Word is not busy and try again."
      Is there something that I can do to fix this?
      Dimitri
        • 1. Re: Publishing to Word
          macrofireball Level 3
          Hello Dimitri,
          I have seen this error message a couple of times. In both cases it was because I had MS Word running. In this first instance please try closing all Word documents and exiting Word it self.
          Note: If you are attempting to open an MS Word 2007 document using Adobe Captivate 2, then you will need to consider upgrading to Adobe Captivate 3. MS Word 2007 documents are not supported in previous versions of Captivate.
          HTH
          Regards - Mark
          • 2. Re: Publishing to Word
            DHMerritt Level 1
            Thank you Mark
            I am using Microsoft 2007 and Captivate 3. I have closed down all office applications. Tried to publish it but still the same problem. I however am not the only one with this problem my colleagues and I are all sitting with this problem. It all started when we upgraded to Captivate 2. All of us are experiencing the same problem i.e. it is not local to my machine.
            Thank you so much for your help. Do you have any other suggestions?
            • 3. Re: Publishing to Word
              Hi Dimitri
              Of course I'm not Mark, but I think it is about 5 AM where he is. I'm wondering if this would have something to do with macro security. I know that we see issues with RoboHelp when we deal with printed output because the templates that are used contain macros. I believe that Captivate may be the same way.
              If I'm guessing correctly here, you may need to relax the security a tad. Just open Word up and click Tools > Macro > Security and reduce it a notch. See if this changes anything.
              I may be off my rocker with this, but it won't hurt anything to try.
              Cheers... Rick
              • 4. Re: Publishing to Word
                DHMerritt Level 1
                Heeeee... Sorry Rick .. .Eish you are not going to believe where I got Mark from... Under your reply it says "Mark this message as the answer" ... hence I only read Mark ... heeee... Sorry
                I read in one of the posts about the Security thang. I played around with it but no luck. This is most probably because I am new to Office 2007 i.e. there is no Tools button. Do you mind if I tell you what I did?
                I clicked on the office button>Word Options>Trust center>Trust center settings>Macro settings> Enable all macros .......
                This however did not help. Should I have set something else?
                Dimitri
                • 5. Re: Publishing to Word
                  Hi Dimitri,
                  Mark here - Since Rick's excellent suggestion did not do the trick, I would suggest that you report this as a bug using the Adobe Captivate Feature Request/Bug Report Form
                  Please do let us know how you get on as it would be useful to know how Adobe managed to fix this issue.
                  Warm regards - Mark
                  • 6. Re: Publishing to Word
                    mrfibuli Level 1
                    Is there hope on the error encountered when publishing (handouts) to Word. I'm running Captivate 3 with Word 2007, and have the problem.
                    • 7. Re: Publishing to Word
                      DHMerritt Level 1
                      mrfibuli I have had no response from them yet, not even a hold on we are trying to fix this.... nothing. I must accept they have forgotten me. So I tell you what, I am going to click on the link again to send a bug to them, why don't you also click on the link and send them a bug report?
                      • 8. Re: Publishing to Word
                        Hi Dimitri
                        If you used the bug reporting form, I would actually be surprised if they contacted you as a result. Most of the time, these are a one way avenue. Just a way for us to feed them issues we find. I might instead suggest you use the Adobe Support link. I just place a link in that last sentence, or you may scroll to the bottom of this page and use theirs.
                        Hopefully this will be helpful... Rick
                        • 9. Re: Publishing to Word
                          DHMerritt Level 1
                          Thank you Rick. Much appreaciated.. hey Happy new year. I went to the link and they want one to pay for the support... mmm ... what happened to the support one receives with the maintanace agreement? This is for my company, I am sure not going to pay for the support. Any other suggestions?
                          • 10. Re: Publishing to Word
                            Hi again Dimitri
                            You asked:
                            If you have some sort of an agreement with Adobe, I would think they should be able to somehow manage to identify your company in their records.
                            But I'm not Adobe. I'm just another Captivate user. Only Adobe can speak to that.
                            Cheers... Rick
                            • 11. Re: Publishing to Word
                              DHMerritt Level 1
                              You da bestest Rick. I contacted Adobe and they are looking into the matter i.e. lets see what happens.
                              Do you know when a new version is due? Or a patch? Or update?
                              • 12. Re: Publishing to Word
                                Hi Dimitri
                                New version? As in Captivate 4? Well, I've heard some talk about it. But I'd have to guess that it's nothing more at this point than a twinkling in Adobe's eye.
                                Assuming a new version were in progress, we would expect to see either an Alpha or a Beta. Neither of those has happened, so even if they were working on something at the moment (and I have no idea whether they are) I'm guessing it would be a good many months away.
                                Cheers... Rick
                                • 13. Re: Publishing to Word
                                  TDNAM Level 1
                                  Yes, this will work.
                                  Sanjay Das
                                  Data Recovery
                                  Ink Cartridges
                                  Data Recovery
                                  • 14. Re: Publishing to Word
                                    Level 7
                                    But if there were one, we wouldn't be allowed to talk about it unless it
                                    were a public Beta ... so, it's a question domed to disappointment all round
                                    Steve
                                    Adobe Community Expert: eLearning, Mobile and Devices
                                    European eLearning Summit - EeLS
                                    Adobe-sponsored eLearning conference.
                                    http://www.elearningsummit.eu
                                    • 15. Re: Publishing to Word
                                      anton1234 Level 1
                                      I have contacted Adobe and they are looking into the matter, lets see what happens.
                                      cartridges raid recovery hard disk recovery
                                      • 16. Re: Publishing to Word
                                        DHMerritt Level 1
                                        Good Day All
                                        Some good news from my side.
                                        I did contact Adobe and they were brilliant. They asked me to do a couple of thangs.. send them some thangs... they sent me some thangs... and eventually these thangs made my Captivate work ... heeeeee.
                                        Honestly they were great and now I have a working version that I am not allowed to use as they are still busy doing some testing ... BUT it works Yeeeehaaaa.... It feels great .. heeee.
                                        Furthermore I see there is big talk about Captivate 4 being in the pipelines. According to a friend there are going to be BIG TIME improvements and enhancements. So I cannot wait.
                                        • 17. Re: Publishing to Word
                                          DHMerritt Level 1
                                          Heeeeeee.... Yip I must say I am totally impressed with them. Why not try them? Man they have over exceeded my expectations... totally.
                                          • 18. Re: Publishing to Word
                                            mixtapez Level 1
                                            Hello Dimitri
                                            Greetings! I am getting the same error when I use Captivate 3 and word 2007.
                                            Did it work for you? Could you please post the steps to get this error fixed.
                                            Sam
                                            • 19. Re: Publishing to Word
                                              DHMerritt Level 1
                                              Good Day Sam
                                              I did not get my version to work. Adobe worked on something and sent me a working version (i.e. a new copy of Captivate). Why not write to them and ask them for help.. they are very friendly and helpful
                                              • 20. Re: Publishing to Word
                                                mixtapez Level 1
                                                Hello Dimitri
                                                Thanks for the update and help. I had a deadline so I installed MS Office 2003 and the output worked like a breeze but still no clue why i wont work in MS Office 2007 :( Its a bummer.
                                                Wish there was a work around to it.
                                                Thanks anyways
                                                Peace
                                                Sam
                                                • 21. Re: Publishing to Word
                                                  mixtapez Level 1
                                                  Hello Sanjay
                                                  Do you have a work around to this error?
                                                  Sam
                                                  • 22. Re: Publishing to Word
                                                    DHMerritt Level 1
                                                    Morning Sam sorry I cannot help you. The file is firstly toooooo BIG to send via email. Secondly Adbobe Captivate advised me not to use it as there might be other bugs (but I do use it ... shh ... do not tell anybody ... heee).
                                                    Did you write to them? I am sure they will give you the same version they gave me. They were real friendly
