6 Replies Latest reply on May 15, 2013 3:54 AM by Learner Learner
    Need to avaid placing floats one after one on the same place
    Learner Learner Level 1
      Hi All,
      I have written a script for placing floats after the citation it works only for either the figure or table. But if both figure and table citation comes on the same place the script placing the floats one on one.
      How to control this?
      Thanks in advance,
      Learner
        • 1. Re: Need to avaid placing floats one after one on the same place
          Jump_Over Level 5
          pretty complex question...
          1. you place them as anchored or as standalone boxes?
          2. how you detect correct "after the citation" place?
          Jarek
          • 2. Re: Need to avaid placing floats one after one on the same place
            Hi Jarek,
            1. standalone boxes
            2. Getting the pagenumber of the citation and the baseline position of the citation
                 if (pagehight-bottommargin) - baseline of the citation > hight of the image)
                 then im placing the image under the citation on the bottom of the same page
                 else
                 im placing the image onto the top of the next page
            thanks
            Learner
            • 3. Re: Need to avaid placing floats one after one on the same place
              Sajeev Sridharan Level 4
              Please clarify the below points:
              is it a XML workflow or non-xml workflow?
              How you are capturing tables and figures in to a standalone boxes?
              Vandy
              • 4. Re: Need to avaid placing floats one after one on the same place
                Hi Vandy,
                It is a xml workflow.
                Here is the script.
                function caption(){
                    this.name = "caption";
                    this.xpath = "//caption";
                          this.apply = function(caption,){
                        with(caption){
                            var mydoc = app.activeDocument;
                            var pwidth = mydoc.documentPreferences.pageWidth;
                            var pheight = mydoc.documentPreferences.pageHeight;
                            var topmargin = app.activeDocument.masterSpreads.item(0).pages.item(0).marginPreferences.top;
                            var bottommargin = app.activeDocument.masterSpreads.item(0).pages.item(0).marginPreferences.bottom;
                            var insidemarginfirstmaserpage = app.activeDocument.masterSpreads.item(0).pages.item(0).marginPreferences.left;
                            var outsidemarginfirstmaserpage = app.activeDocument.masterSpreads.item(0).pages.item(0).marginPreferences.right;
                            var y1 = topmargin;
                            var x1 = outsidemarginfirstmaserpage;
                            var y2 = pheight - bottommargin;
                            var x2 = pwidth- insidemarginfirstmaserpage;
                            citpage = figCitationPage.name;
                            textfm = placeIntoFrame(app.activeDocument.pages.item(citpage), [y1, x1, y2, x2]);
                            textfm.fit(FitOptions.FRAME_TO_CONTENT);
                            textfm.appliedObjectStyle = mydoc.objectStyles.item("oSlug");
                            mydoc.xmlImportMaps.add(mydoc.xmlTags.item("caption"), mydoc.paragraphStyles.item("Slug"));
                            mydoc.mapXMLTagsToStyles();
                            textfm.textWrapPreferences.textWrapMode = TextWrapModes.BOUNDING_BOX_TEXT_WRAP;
                            textfm.textFramePreferences.ignoreWrap = true;
                            var textfmy1 = textfm.geometricBounds[0];
                            var textfmx1 = textfm.geometricBounds[1];
                            var textfmy2 = textfm.geometricBounds[2];
                            var textfmx2 = textfm.geometricBounds[3];
                            figfmy1 = figfm.geometricBounds[0];
                            figfmx1 = figfm.geometricBounds[1];
                            figfmy2 = figfm.geometricBounds[2];
                            figfmx2 = figfm.geometricBounds[3];
                            textfm.geometricBounds = [textfmy1,textfmx1,textfmy2,x2];
                            textfm.move([textfmy1, figfmy2]);
                            var myPage = mydoc.pages.everyItem();
                            var myArray = new Array;
                            myArray.push(figfm);
                            myArray.push(textfm);
                            var t = (textfmy2-textfmy1)
                            var groupitem = figCitationPage.groups.add(myArray);
                            var citbaseline = exbm - citpos;
                            var test = parseInt(citpage)
                            if (citbaseline<groupitem.geometricBounds[2]){
                                    groupitem.move(app.activeDocument.pages[test]);
                                    groupitem.move([x1,y1])
                            else {
                                    var by1 = groupitem.geometricBounds[0];
                                    var by2 = groupitem.geometricBounds[2];
                                    var t = (by2-by1)
                                    groupitem.move([x1, (y2-t)])
                        return true;
                function figure(){
                    this.name = "figure";
                    this.xpath = "//figure";
                          this.apply = function(figure,){
                        with(figure){
                            //var insidemarginsecondmaserpage = app.activeDocument.masterSpreads.item(0).pages.item(1).marginPreferences.left;
                            //var outsidemarginsecondmaserpage = app.activeDocument.masterSpreads.item(0).pages.item(1).marginPreferences.right;
                            var y1 = topmargin;
                            //var x1recto = AMinsidemargin
                            //var x2recto = pwidth- AMoutsidemargin;
                            figfm = placeIntoFrame(app.activeDocument.pages.item(citpage), [y1, x1, y2, x2]);
                            figfm.fit(FitOptions.FRAME_TO_CONTENT);
                            figfm.textWrapPreferences.textWrapMode = TextWrapModes.BOUNDING_BOX_TEXT_WRAP;
                            figfm.textFramePreferences.ignoreWrap = true;
                            figfm.appliedObjectStyle = mydoc.objectStyles.item("ofigure");
                            fy1 = figfm.geometricBounds[0];
                            fx1 = figfm.geometricBounds[1];
                            fy2 = figfm.geometricBounds[2];
                            fx2 = figfm.geometricBounds[3];
                        return true;
                • 5. Re: Need to avaid placing floats one after one on the same place
                  one final question, can you tell me the xml structure of figures, tables and citation tags used in the indesign document.
                  Vandy
                  • 6. Re: Need to avaid placing floats one after one on the same place
                    Hi Vandy,
                    Figure : component/body/section/figure
                    Figure caption : component/body/section/figure/caption
                    Citation : component/body/section/p/link
