9 Replies Latest reply on May 20, 2013 1:46 PM by Trevorׅ
    hyperlinkTextSources from hyperlinkTextDestinations text
    foredit
      Hi Scripters, big question!!!
      With two documents open, I have some hyperlinkTextDestinations previously created by text selections.
      Now want to create hyperlinks with hyperlinkTextSources refering to the same text used for anchors.
      Trying for hours several solutions and roaming the web with no success, here's a test script:
      var myLink = app.documents[0].hyperlinkTextDestinations[0].destinationText.select();
      var mySource = app.documents[0].hyperlinkTextSources.add(myLink);
      var myAnchor = app.documents[1].hyperlinkTextDestinations[0];
      app.documents[0].hyperlinks.add(mySource, myAnchor);
      The prob is that i get (line 1) an insertionPoint instead a text selection.
      Any indications appreciated,
      regards
        • 1. Re: hyperlinkTextSources from hyperlinkTextDestinations text
          SuriyaRevathi Rengan
          -- by using apple script -> u converted this into java script
          eg :  set mydoc to active document -> apple script
              var myDoc = app.activeDocument -> java script
          select text of selection
                          set SourceText to item 1 of selection as string
                          set hrperlnk to hyperlinks
                          set LnkTxt to 0
                          set HyperLnkTxt to hyperlink text sources
                          repeat with i from 1 to count of HyperLnkTxt
                              set HyperLnkSrc to item i of HyperLnkTxt
                              set src to contents of source text of HyperLnkSrc
                              if src is equal to SourceText then
                                  set LnkTxt to 1
                                  exit repeat
                              end if
                          end repeat
          • 2. Re: hyperlinkTextSources from hyperlinkTextDestinations text
            foredit Level 1
            Thank you SuriyaRevathi,
            but, if I've right understood your script, a selected text is my target (js line 1) not my starting point (it will be at js line 2)
            • 4. Re: hyperlinkTextSources from hyperlinkTextDestinations text
              foredit Level 1
              Thanks Trevor,
              very useful post confirming that looking for hyperlinkTextDesination it just gets an insertionPoint and not contents.
              I need to create bidirectional hyperlinks (text to note, note to text) this is why i want to transform an anchor in a source too.
              Now from this Select one or more characters after insertion point (thank you for reply) i will try.
              regards
              • 5. Re: hyperlinkTextSources from hyperlinkTextDestinations text
                Trevorׅ Adobe Community Professional
                Hi Foredit,
                Remember you can only create bidirectional hyperlinks if each destination only has one source.
                Is that the case by you?
                Trevor.
                P.s. Please mark the other post as answered.
                • 6. Re: hyperlinkTextSources from hyperlinkTextDestinations text
                  foredit Level 1
                  Yes, it is
                  Thank you Trevor
                  • 7. Re: hyperlinkTextSources from hyperlinkTextDestinations text
                    Ok, here's a start
                    See before and after screenshots
                    Read the warning
                    Before:
                    After:
                    Click the shots to see them clearly
                    The script:
                    // Make new bidirectional hyperlinks from existing unidirectional ones
                    // By Trevor http://forums.adobe.com/thread/1212690?tstart=0
                    // WARNING ONLY WILL (IF LUCKY) WORK IF THERE ARE NO SOURCES IN THE NEW DESTINATION
                    // MEENS THAT YOU CAN'T RUN IT TWICE
                    // BUT YOU CAN DO CTRL / OPTION Z TO UNDO
                    app.doScript("main()", ScriptLanguage.JAVASCRIPT, undefined, UndoModes.ENTIRE_SCRIPT, "Make Inverse Hyperlinks");
                    function main()
                            var doc= app.activeDocument,
                                   myHyperlinks =doc.hyperlinks.everyItem().getElements(),
                                   l = myHyperlinks.length;
                            var hypSource, hypDestination, newDestinationName, hdps, hypDestinationPos, newDestination, newSource, newHL;
                            while (l--)
                                    hypSource = myHyperlinks[l].source.sourceText;
                                    hypDestination = myHyperlinks[l].destination.destinationText;
                                    newDestinationName = hypSource.contents;
                                    hdps = hypDestination.parentStory;
                                    hypDestinationPos = Math.min(hdps.texts.itemByRange (0, hypDestination.insertionPoints[0].index).words.length - 1, 0);
                                    newDestination = doc.hyperlinkTextDestinations.add(hypSource);
                                    newDestination.name = newDestinationName + " ... " + newDestination.id + "_";
                                    newSource =  doc.hyperlinkTextSources.add(hypDestination.paragraphs[0].characters.itemByRange(0,-1));
                                    newHL = doc.hyperlinks.add(newSource, newDestination, {});
                                    newHL.name = newSource.sourceText.contents.slice(0, Math.min(20, newSource.sourceText.contents.length)) + " ... " + newHL.id + "_";
                                    //newHL.source.sourceText.appliedCharacterStyle="2";
                    Trevor
                    • 8. Re: hyperlinkTextSources from hyperlinkTextDestinations text
                      foredit Level 1
                      Interesting script i'll study for sure but it assume hyperlinks and anchors already in the document.
                      Workin' on epub with endnotes i've previously created all anchors with the same name in both documents (text document and notes document).
                      From this scenario i've to create hyperlinks from text to note and back again.
                      Starting from insertionPoint, by me, solution could be to select anchor text and add hyperlink matching anchor's name.
                      Exporting epub there would be something like this in xhtml documents.
                      text.xhtml
                      <a id="n1c1" href="notes.xhtml#n1c1">1</a>
                      notes.xhtml
                      <a id="n1c1" href="text.xhtml#n1c1">1</a>
                      I hope not confusing you
                      best regards
                      • 9. Re: hyperlinkTextSources from hyperlinkTextDestinations text
                        Hi Foredit,
                        I didn't realize that you were working on an epub I would have to look into that and it would take me quite a bit of time.
                        As you are doing try use the imformation from your recent treads to figure it out and start more threads as required.
                        If you get desperate then I'm always happy to take a job for money
                        Regards
                        Trevor
