1. Re: This is a bit of information for folks that use Robohelp for Word.
Peter Grainge May 17, 2013 1:45 AM (in response to Theodorakis55)Thanks for posting this Peggy.
It is worth adding that there is another way of continuing to work with Word - using Linked Documents in RoboHelp HTML. You create Word documents entirely independent of RoboHelp and then create topics by linking those documents in a RoboHelp HTML project.
You cannot create WinHelp that way but WinHelp is on life support and requires users to download a viewer, you cannot distribute it. It really is time to move on from WinHelp.
RoboHelp for Word is not getting much development and does not get the new features being added to RoboHelp HTML.
Linking is covered on my site.
2. Re: This is a bit of information for folks that use Robohelp for Word.
Theodorakis55 May 21, 2013 10:32 AM (in response to Peter Grainge)Thanks for the feedback. i've had bad luck converting my winhelp to Robohelp HTML. Lost tons of links when I did. It worked better when I compiled in webhelp but using Robohelp for Word. It does everything I need it to do, including directly linking pdf, excel, power points etc. It runs on windows 7 and can use Office 10 (with patch). Any new projects I'll work in RH HTML but my old projects just don't take well to conversion. Like one of my projects has over 100,000 links to external documents....I have no desire to relink everything.
I am compiling in WEBHELP (single source) instead of winhelp, but still using RH for Word. It works so everyone is happy.
3. Re: This is a bit of information for folks that use Robohelp for Word.
Peter Grainge May 21, 2013 10:41 AM (in response to Theodorakis55)OK but if you do decide to give conversion another go I would try generating a CHM from RoboHelp for Word and then reverse engineering that as covered on my site. I am not guaranteeing it will be seamless but it's worth a shot.
100.000 links? Sheesh.
4. Re: This is a bit of information for folks that use Robohelp for Word.
Freespirit-ST Sep 12, 2013 8:03 AM (in response to Peter Grainge)Just seeing, and needing, this information now. I have a RoboHelp for Word project, in RH8, that may need to run in Windows 7. I can't convert it, because it is context-sensitive to our system (one of them) - and all the attachment links are hard-coded into the system, so would take an enormous effort to change the code. This is our only RH for Word project, and the system is barely used - but occasionally needs an update.
So, if we had our users download WinHelp32.EXE into the appropriate Help installation file location, would this HLP work?? It's a Winhelp 2000 with the tri-pane presentation. (Looking for a quick fix here.)
Thanks as always for your assistance, Peter!
5. Re: This is a bit of information for folks that use Robohelp for Word.
Peter Grainge Sep 14, 2013 7:50 AM (in response to Freespirit-ST)Users can download a link that will make a HLP file run. Whether or not Rh8 for Word will run under Windows 7 is another matter. Rh8 HTML was patched during its lifetime to run under Windows 7 but I don't know if that applied to Rh8 for Word.
I think you are just going to have to try it.
6. Re: This is a bit of information for folks that use Robohelp for Word.
David Hurlston Sep 21, 2013 12:31 PM (in response to Peter Grainge)We generate legacy WH2000 projects all day long that run properly under Vista/Win7/Win8. Maybe you didn't do the registry tweak needed for macros to run properly, or you are running on an intranet. Take a close look at the knowledge base article at http://support.microsoft.com/kb/917607
We also generate WebHelp and HTML5 multi-screen. We have found that converting a WH2000 project hpj to multi-screen is not completely trouble-free and some work is needed on the Word files to get the correct output.
All in all, it's best to get off WinHelp. Odds are you will be forced to do it sooner or later anyway given Microsoft's aversion to it
