2 Replies Latest reply on May 20, 2013 2:54 PM by LeandroAmano
    load html made by edge into other html made by edge
    LeandroAmano
      Hi guys,
      I have a menu with contains some buttons, every button calls a html file generated by edge. But it works only one time. The second click event not works. Any suggestions?
      Thanks in advance!
      The code on click event:
      this.links = ["home.html", "gallery.html", "contact.html"];
      sym.$("btn" + i).bind("click", {
                          htmlFile : this.links[i]
                }, function(e) {
                          if(e.target == sym.selectedItem){
                                    return;
                          sym.$(sym.selectedItem).animate({opacity:1}, 300, "linear");
                          sym.$(e.target).animate({opacity:0.4}, 600, "linear");
                          sym.selectedItem = e.target;
                          sym.$("#target").load(e.data.htmlFile);
                          e.preventDefault();
        • 1. Re: load html made by edge into other html made by edge
          Zaxist Level 4
          you can use iframe
          make a symbol called LoadFrame then copy paste these codes in compositionReady
          sym.$("LoadFrame").append('<iframe id="LoadFrame"src="your edge folder address/index.html" frameborder="0" scrolling="no"></iframe>');
          sym.$("#LoadFrame").css({"height":"100%","width":"100%"});
          if you wanted to remove use this code:
          sym.$("#LoadFrame").detach();
          Zaxist
          • 2. Re: load html made by edge into other html made by edge
            LeandroAmano Level 1
            I found this:
            yepnope({
                      load: [
                                "libs/EdgeCommons.js"
                      complete: function(){
                                // Center Stage
                                EC.centerStage(sym);
                                sym.$("btn").click(function() {
                                          EC.loadComposition( "SpritesheetAnimation.html", sym.getSymbol("content") );
            Tks Zaxist.
