1 Reply Latest reply on May 16, 2013 11:23 AM by Manish-Sharma
    InDesign Appcrash
    gfRich
      The problem can be summed up by saying, when an Indesign file is double-clicked on, through either Explorer or Bridge, InDesign crashes. with the following information:
      Problem signature:
        Problem Event Name: APPCRASH
        Application Name: InDesign.exe
        Application Version: 8.0.1.406
        Application Timestamp: 50335e39
        Fault Module Name: Public.dll
        Fault Module Version: 8.0.1.406
        Fault Module Timestamp: 50335d6f
        Exception Code: c0000005
        Exception Offset: 0006a7b1
        OS Version: 6.1.7601.2.1.0.256.48
        Locale ID: 1033
        Additional Information 1: 0a9e
        Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
        Additional Information 3: 0a9e
        Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
      I just installed Adobe CS6 Design on four PC's, all of which are Win7 64-bit, updated with MS updates. Adobe CS6 is also updated. CS5 was previously installed on the four PC's.
      On one of the PC's (which I'm focusing on), I un-installed the upgrade, ran the cleaner. and reinstalled CS6, I'm still having the issue.
      When InDesign is open and a file is double-clicked on (thru Bridge or Explorer), InDesign does not crash.
      Perhaps some noteworthy points:
      • Changing the default printer doesn't make a difference.
      • Opening Photoshop or Illustrator files doesn't crash those programs.
      • We use Sophos AV, which is centrally managed, so I wasn't able to uninstall it.
      • PC's are desktop, so there always connected to the network.
      Any other thoughts for troubleshooting?
      Thank you.
      Rich
        • 1. Re: InDesign Appcrash
          Manish-Sharma Employee Moderator
          You wrote that you have 4 machine on which you have installed InDesign. Does all the 4 computer give you issue with the InDesign or it is just one machine.
          This my help you narrow down the issue.
          If the issue is occuring on all the 4 machine then you might want to look into common components.
          Below are the few steps you might want to try:-
          1) Third party plugins. - If present, you can remove those and then check
          2) Network Configration -- Disconnect the network on one machine to make it standalone and then check
          3) Perform selective startup to see if there is a third party software conflict. This might help :- http://helpx.adobe.com/x-productkb/global/disable-startup-items-services-windows.html
