3 Replies Latest reply on May 20, 2013 10:09 AM by iccsi
    iccsi Level 1
      I would like to use user input as CFQUERYPARAM for example,
      I have txtMyID on the form and would like to use user input as my query parameter.
      I tried to use
        <cfqueryparam value = "#trim(form.txtMyID)#" CFSQLTYPE = "cf_sql_integer">
        but does not work,
      I tried the following which works, but I need get the value from user enter.
        <CFSET MyID = "1">
        <cfqueryparam value = "#MyID#" CFSQLTYPE = "cf_sql_integer">
      Your help and information is great appreciated,
        • 1. Re: CFQUERYPARAM
          BreakawayPaul Level 2
          Can you see if cf_sql_numeric works as the type?  I've had problems with integer before.  Also, make sure the data type of your column matches whatever your CFSQLTYPE is.
          • 2. Re: CFQUERYPARAM
            mkane1 Level 1
            The problem is likely with the value of trim(form.txtMyID). Directly using FORM variables is not a good idea, for a variety of reasons. It is better to initialize all your variables as uniquely named local page variables, and then assign values from FORM or other inputs after validating them.
            <cfset ThistxtMyID = "0">
            <cfif IsDefined("FORM.txtMyID") AND IsValid("integer", Trim(FORM.txtMyID)>
                <cfset ThistxtMyID = Trim(FORM.txtMyID)>
            Be sure to validate ThistxtMyID before you try to use it:
            <cfif ThistxtMyID EQ "0">
            handle this error condition, don't query the database
            • 3. Re: CFQUERYPARAM
              iccsi Level 1
              Thanks a million for the information and help,
