4 Replies Latest reply on May 20, 2013 7:55 PM by Trecool_182
    Trouble with fonts/lines weight
    Trecool_182
      Hello everyone,
      I am coming to you because I have a problem for which i cannot see any solution... I am not specialized in indesign, but yet I used it for a long time and this problem looks really strange for me. I will directly show you a picture :
      Here are also diret links to bigger pictures :
      http://i83.servimg.com/u/f83/10/05/57/17/bold10.jpg
      http://www.servimg.com/u/f83/10/05/57/17/light10.jpg
      (right click > open in new tab, then switch between tabs to see the problem)
      As you can see, the weight of text and lines change between the documents. The problem is, there are supposed to be exactly the same, as they come from the same master. (these pictures are just an example, i have the same problem for about half of my pages). When I unlink both from the master with ctrl+shift+click, then i delete the light one and try to copy the bold one, the problem remains, showing it is not an object issue but more a page issue. Problem is, I created those pages by dupplicating them when needed... so they really should be the same.
      Of course, i thought at the beginning it was an indesign problem, but when I export it to pdf, the problem remains. And the worst is, it is still there after print, making the light one almost unreadable.
      When i export to eps and put it in adobe distiller, the problem is fixed for texts! But it remains on any non-text object, like the scissors and scissors-lines.
      I don't really know what I can do, and my timeline is getting really close. Thanks in advance for reading, and thanks alot to anyone who can give me an idea of what to look for.
      Please note that i use indesign cs6.
      Regards,
      Antoine
        • 1. Re: Trouble with fonts/lines weight
          Salah Fadlabi Level 5
          Can you attach indesign file of just these 2 pages.
          • 2. Re: Trouble with fonts/lines weight
            I think what you are seeing is a transparency artifact that has the effect of making text on pages look bolder than text on pages without transparency. The effect is visible in ID, and in PDF on screen or when printed on low-resolution devices, but generally is not seen in high-resolution output on a press. This is a well-known issue in ID, and there's nothing you can do about it other than make sure that all pages have transparency if any page will have it and the effect is bothersome.
            But I noticed another issue that I can't as easily explain when shifting between the images. There seems to be more space between the top line of text and the empty rectangles below it in the bolder version than there is in the lighter version. Is that something you've done?
            • 3. Re: Trouble with fonts/lines weight
              Trecool_182 Level 1
              Yeah this is something i've done, because the text above we don't see here is bigger. But it sure isn't because of this, as I have said I have the same probleme on lots of pages, and it does it for the whole content of the page, including master's elements or unique elements. Only objetcs where there isn't problem is on imported photos... Also, please note that i see the problem on high quality offset industrial printers, the one which will be used to print the thousand of pages in a few days.
              Ok i just tried a lot of things to upload the pages here. I went through modifications and all, to send you two fake pages. At the end of modifications the problem was gone... So by watching every step of the modifications i made i identified the problem :
              The lines and fonts get thin when i put pictures on the spread (it gets thin if i put pictures on the facing page also) and it's getting back in bold when i delete them. Now that i know this, i can see that indeed every pages with pictures are the pages with thin lines... the thing is, i will have to put pictures on every pages.
              Pictures are psd in CMYK japan coated if this can help.
              I'll let you know if i find the solution, in the meantime thank you if you have any tip
              If i don't find anything i may just make the font a bit bolder, but I don't really like this solution because text placement is really precise in some pages.
              Thanks a lot for your answers!
              • 4. Re: Trouble with fonts/lines weight
                Trecool_182 Level 1
                Ok then, i found the problem...
                So please note to everyone reading this, don't use psd with dynamic objetcs in your indesign projects... Because that was the problem^^ I flattened all my psd and problem is gone. Thanks again!
