4 Replies Latest reply on May 20, 2013 2:22 AM by keyjonathan
    Photoshop CS6 64bit has stopped working
    keyjonathan
      Details as follows:
      Event Viewer:
      Faulting application name: Photoshop.exe, version: 13.0.0.0, time stamp: 0x4f61c045
      Faulting module name: ntdll.dll, version: 6.1.7601.17725, time stamp: 0x4ec4aa8e
      Exception code: 0xc0000005
      Fault offset: 0x000000000003cb98
      Faulting process id: 0x19ec
      Faulting application start time: 0x01ce4d4dc079aa6d
      Faulting application path: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Photoshop.exe
      Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
      Report Id: fe64122d-b940-11e2-b5ef-c86000c5d65e
      Windows 7, 32GB, 64bit system
      I have already tried:
      Reseting PS preferences, reinstalling PS, updating all my drivers, renaming the plugin folder temporarily.
      Some other people with the same problems:
      http://forums.adobe.com/message/3165008
      http://forums.adobe.com/message/4561493
      http://feedback.photoshop.com/photoshop_family/topics/photoshop_cs6_64 _crashes_while_loading_ntdll_dll_error
      http://www.errordetails.com/575/ntdll-dll-error-when-opening-a-file-in -photoshop
      The weird thing is the other 64 bit Adobe stuff works fine, hopefully Adobe can fix whatever cause it
      Please help, thanks
      http://forums.adobe.com/servlet/JiveServlet/downloadImage/2-5307951-327912/450-473/Capture.PNG
        • 1. Re: Photoshop CS6 64bit has stopped working
          Level 5
          keyjonathan wrote:
          …Faulting application name: Photoshop.exe, version: 13.0.0.0…
          You haven't applied any of the Photoshop updates.  No one should be running that old, obsolete buggy version of Photoshop.
          keyjonathan wrote:
          …Faulting application path: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Photoshop.exe
          I'm merely pointing this out so that those more conversant with Windows (one of which I am definitely not) can explain how that faulting module path can lead to the SYSTEM32 directory when the 64-bit Ps binary is running.  Being a Mac user myself, I have no insight into this, a similar occurrence of which I pointed out in another recent thread with the same flag without being able to explain it.
          Message was edited by: station_two
          • 2. Re: Photoshop CS6 64bit has stopped working
            NTdll crashes are eitehr file I/O or kernel driver crashes. Something is incompatible on your system. Check your device manager and make sure all your drivers are actually 64bit native and don't run in compatibility modes. Uninstall portentially incompatible devices like scanners or printers to test...
            Mylenium
            • 3. Re: Photoshop CS6 64bit has stopped working
              keyjonathan Level 1
              Faulting application name: Photoshop.exe, version: 13.1.2.0, time stamp: 0x50e86765
              Faulting process id: 0xf44
              Faulting application start time: 0x01ce553b09791f20
              Report Id: 47cde300-c12e-11e2-93b3-c86000c5d65e
              Sorry, that event was from 2 weeks ago, I started a thread but no one replied. You can see above that I've updated and same problem.
              • 4. Re: Photoshop CS6 64bit has stopped working
                keyjonathan Level 1
                Thanks, this is helpful, I'll try uninstalling my scanner/printer/tablet drivers to see if that solves it.
