1 Reply Latest reply on May 20, 2013 4:02 PM by Bramblethorne
    Spark List replaces first ItemRenderer w/internal typicalItem instantiation.
    Bramblethorne
      From the View that houses the Spark List component:
      protected function creationCompleteHandler():void
         // trace("MakeAToolLearnItView FUNCTION creationCompleteHandler")
          addBlankItem("yell");
          addBlankItem("shout");
          addBlankItem("blather");
          addBlankItem("cry");
      protected function addBlankItem(s:String):void
          //trace("MakeAToolLearnItView FUNCTION addBlankItem")
          var len:uint = itemArray.length+1;
          var obj:Object = new Object();
          obj.numberLabel = len;
          obj.scream = s;
          itemArray.addItemAt(obj, itemArray.length);
      override protected function getToolData():void
          trace("MakeAToolLearnItView FUNCTION setToolData")
          tooldata = <rows> </rows>;
          trace("itemArray.length: "+itemArray.length);
          for(var i:uint = 0; i < itemArray.length; i++)
              trace("------ itemArray[i]: "+itemArray[i].p);
              trace("------ itemArray[i].scream: "+itemArray[i].scream);
              trace("------ itemArray[i].behaviorNameTextInput.text: "+itemArray[i].behaviorNameTextInput.text);
              var xml:XML =
                  <row>
                      <rowNum>{itemArray[i].numberLabel}</rowNum>
                      <behaviorName>{itemArray[i].behaviorNameTextInput.text}</behaviorName>
                      <behaviorDescription>{itemArray[i].behaviorDescriptionTextArea.id}</behaviorDescription>
                  </row>;
              xml.appendChild(itemArray[i].choosePictureButton.getMediaXML());
              tooldata.appendChild(xml);
      Console output for that  code snippet: Note: I entered 'a' and 'b' in the TextInput and TextArea components, 'c' and 'd' in the second and so on.
      Note the difference between Red and the Violet. I am all the more confused that it has the proper 'scream' property but is definitely not the one I typed input into... also that my 'length' is 4 (substitution as opposed to addition I suppose)
      itemArray.length: 4
      ------ itemArray[i]: LearnItListItemRenderer166
      ------ itemArray[i].scream: yell
      PictureToolsOnTheMoveMakeIt0.TabbedViewNavigatorApplicationSkin6.tabbedNavigator.TabbedVie wNavigatorSkin8.contentGroup.makeATool.ViewNavigatorSkin13.contentGroup.MakeAToolLearnItVi ew148.SkinnableContainerSkin149.contentGroup.itemList.ListSkin152.Scroller154.ScrollerSkin 155.DataGroup153.LearnItListItemRenderer238
      ------ itemArray[i].scream: shout
      ------ itemArray[i].behaviorNameTextInput.text: c
      PictureToolsOnTheMoveMakeIt0.TabbedViewNavigatorApplicationSkin6.tabbedNavigator.TabbedVie wNavigatorSkin8.contentGroup.makeATool.ViewNavigatorSkin13.contentGroup.MakeAToolLearnItVi ew148.SkinnableContainerSkin149.contentGroup.itemList.ListSkin152.Scroller154.ScrollerSkin 155.DataGroup153.LearnItListItemRenderer274
      ------ itemArray[i].scream: blather
      ------ itemArray[i].behaviorNameTextInput.text: e
      PictureToolsOnTheMoveMakeIt0.TabbedViewNavigatorApplicationSkin6.tabbedNavigator.TabbedVie wNavigatorSkin8.contentGroup.makeATool.ViewNavigatorSkin13.contentGroup.MakeAToolLearnItVi ew148.SkinnableContainerSkin149.contentGroup.itemList.ListSkin152.Scroller154.ScrollerSkin 155.DataGroup153.LearnItListItemRenderer310
      ------ itemArray[i].scream: cry
      ------ itemArray[i].behaviorNameTextInput.text: g
      Here is the relevant section of the custom ItemRenderer associated with this Spark List:
      [Bindable]
      public var dataProxy:ObjectProxy;
      [Bindable]
      public var v:MakeAToolBase;
          trace("LearnItListItemRenderer FUNCTION creationCompleteHander");
          trace("\n------- this:\n"+this);
          dataProxy = new ObjectProxy(data);
           trace("------- My Heart Yearns To: ");
          dataProxy.choosePictureButton = choosePictureButton as ChoosePictureButton;
          dataProxy.behaviorNameTextInput = behaviorNameTextInput as TextInput;
          dataProxy.behaviorDescriptionTextArea = behaviorDescriptionTextArea as TextArea;
          dataProxy.p = this as LearnItListItemRenderer;
      And the console output:  Again, note the difference between Red and the Violet, and that there is now 5 (as expected, dataProvider + layout instance) instead of 4, and the order of the trace statements does not reflect the order of object instantiation (yell, shout, blather, cry) and that the 5th object (for measuring) has the property 'yell'.... though I suppose that's to be expected if the first one instantiated is duplicated, properties and all as the typicalItem.
      ------- this: PictureToolsOnTheMoveMakeIt0.TabbedViewNavigatorApplicationSkin6.tabbedNavigator.TabbedVie wNavigatorSkin8.contentGroup.makeATool.ViewNavigatorSkin13.contentGroup.MakeAToolLearnItVi ew148.SkinnableContainerSkin149.contentGroup.itemList.ListSkin152.Scroller154.ScrollerSkin 155.DataGroup153.LearnItListItemRenderer202
      ------- My Heart Yearns To: cry
      ------- this: PictureToolsOnTheMoveMakeIt0.TabbedViewNavigatorApplicationSkin6.tabbedNavigator.TabbedVie wNavigatorSkin8.contentGroup.makeATool.ViewNavigatorSkin13.contentGroup.MakeAToolLearnItVi ew148.SkinnableContainerSkin149.contentGroup.itemList.ListSkin152.Scroller154.ScrollerSkin 155.DataGroup153.LearnItListItemRenderer238
      ------- My Heart Yearns To: yell
      ------- this: PictureToolsOnTheMoveMakeIt0.TabbedViewNavigatorApplicationSkin6.tabbedNavigator.TabbedVie wNavigatorSkin8.contentGroup.makeATool.ViewNavigatorSkin13.contentGroup.MakeAToolLearnItVi ew148.SkinnableContainerSkin149.contentGroup.itemList.ListSkin152.Scroller154.ScrollerSkin 155.DataGroup153.LearnItListItemRenderer310
      ------- My Heart Yearns To: blather
      ------- this: PictureToolsOnTheMoveMakeIt0.TabbedViewNavigatorApplicationSkin6.tabbedNavigator.TabbedVie wNavigatorSkin8.contentGroup.makeATool.ViewNavigatorSkin13.contentGroup.MakeAToolLearnItVi ew148.SkinnableContainerSkin149.contentGroup.itemList.ListSkin152.Scroller154.ScrollerSkin 155.DataGroup153.LearnItListItemRenderer274
      ------- My Heart Yearns To: shout
      ------- this:
        • 1. Re: Spark List replaces first ItemRenderer w/internal typicalItem instantiation.
          Bramblethorne Level 1
          Setting useVirtualLayout="false" of course fixes all, but I'm rather concerned that this behavior is -very- incorrect.   Seems a bad trade to lose the benefits of the virtual layout if this is a bug. At least it's not rendering an extra very expensive ItemRenderer which was VERY costly in terms of time on an iPad2. Here are the expected results:
          MakeAToolView FUNCTION clickMakeAToolButton(LearnItButton)
          MakeAToolView FUNCTION navigateToTool(LearnItButton)
          ------- PictureToolsOnTheMoveMakeIt0.TabbedViewNavigatorApplicationSkin6.tabbedNavigator.TabbedVi ewNavigatorSkin8.contentGroup.makeATool.ViewNavigatorSkin13.contentGroup.MakeAToolLearnItV iew327.SkinnableContainerSkin328.contentGroup.itemList.ListSkin331.Scroller333.ScrollerSki n334.DataGroup332.LearnItListItemRenderer344
          ------- PictureToolsOnTheMoveMakeIt0.TabbedViewNavigatorApplicationSkin6.tabbedNavigator.TabbedVi ewNavigatorSkin8.contentGroup.makeATool.ViewNavigatorSkin13.contentGroup.MakeAToolLearnItV iew327.SkinnableContainerSkin328.contentGroup.itemList.ListSkin331.Scroller333.ScrollerSki n334.DataGroup332.LearnItListItemRenderer378
          ------- PictureToolsOnTheMoveMakeIt0.TabbedViewNavigatorApplicationSkin6.tabbedNavigator.TabbedVi ewNavigatorSkin8.contentGroup.makeATool.ViewNavigatorSkin13.contentGroup.MakeAToolLearnItV iew327.SkinnableContainerSkin328.contentGroup.itemList.ListSkin331.Scroller333.ScrollerSki n334.DataGroup332.LearnItListItemRenderer412
          ------- PictureToolsOnTheMoveMakeIt0.TabbedViewNavigatorApplicationSkin6.tabbedNavigator.TabbedVi ewNavigatorSkin8.contentGroup.makeATool.ViewNavigatorSkin13.contentGroup.MakeAToolLearnItV iew327.SkinnableContainerSkin328.contentGroup.itemList.ListSkin331.Scroller333.ScrollerSki n334.DataGroup332.LearnItListItemRenderer446
          itemArray.length: 4
          ------ itemArray[i]: PictureToolsOnTheMoveMakeIt0.TabbedViewNavigatorApplicationSkin6.tabbedNavigator.TabbedVi ewNavigatorSkin8.contentGroup.makeATool.ViewNavigatorSkin13.contentGroup.MakeAToolLearnItV iew327.SkinnableContainerSkin328.contentGroup.itemList.ListSkin331.Scroller333.ScrollerSki n334.DataGroup332.LearnItListItemRenderer344
          ------ itemArray[i].behaviorNameTextInput.text: a
          ------ itemArray[i]: PictureToolsOnTheMoveMakeIt0.TabbedViewNavigatorApplicationSkin6.tabbedNavigator.TabbedVi ewNavigatorSkin8.contentGroup.makeATool.ViewNavigatorSkin13.contentGroup.MakeAToolLearnItV iew327.SkinnableContainerSkin328.contentGroup.itemList.ListSkin331.Scroller333.ScrollerSki n334.DataGroup332.LearnItListItemRenderer378
          ------ itemArray[i]: PictureToolsOnTheMoveMakeIt0.TabbedViewNavigatorApplicationSkin6.tabbedNavigator.TabbedVi ewNavigatorSkin8.contentGroup.makeATool.ViewNavigatorSkin13.contentGroup.MakeAToolLearnItV iew327.SkinnableContainerSkin328.contentGroup.itemList.ListSkin331.Scroller333.ScrollerSki n334.DataGroup332.LearnItListItemRenderer412
          ------ itemArray[i]: PictureToolsOnTheMoveMakeIt0.TabbedViewNavigatorApplicationSkin6.tabbedNavigator.TabbedVi ewNavigatorSkin8.contentGroup.makeATool.ViewNavigatorSkin13.contentGroup.MakeAToolLearnItV iew327.SkinnableContainerSkin328.contentGroup.itemList.ListSkin331.Scroller333.ScrollerSki n334.DataGroup332.LearnItListItemRenderer446
          MakeAToolBase FUNCTION saveTool()
          <tool cdate="1369090803000" userid="000000" toolType="Learn-It" version="1" toolName="">
            <filename>000000Tool1369090803000.xml</filename>
            <history>
              <save>1369090811538</save>
            </history>
            <tooldata>
              <rows>
                <row>
                  <rowNum>1</rowNum>
                  <behaviorName>a</behaviorName>
                  <behaviorDescription>behaviorDescriptionTextArea</behaviorDescription>
                  <media type="">
                    <mediaXMLFilename/>
                  </media>
                </row>
                <row>
                  <rowNum>2</rowNum>
                  <behaviorName>c</behaviorName>
                  <media type="">
                    <mediaXMLFilename/>
                  </media>
                </row>
                <row>
                  <rowNum>3</rowNum>
                  <behaviorName>e</behaviorName>
                  <media type="">
                    <mediaXMLFilename/>
                  </media>
                </row>
                <row>
                  <rowNum>4</rowNum>
                  <behaviorName>g</behaviorName>
                  <media type="">
                    <mediaXMLFilename/>
                  </media>
                </row>
              </rows>
            </tooldata>
            <students/>
          </tool>
