7 Replies Latest reply on May 21, 2013 10:49 AM by John T Smith
    PrE11 won't start after adding drive & changing other drive letters
    Jesse Locke
      I relied on some of the posts on this board to determine what my computer build should be. Now I need to ask the help of it's members after the fact. Premiere Elements 11 will no longer launch.
      With the exception of my OS drive C: I changed my drives from:
      C: OS 320GB WD
      D: CD-writer
      E: Bluray player
      F: 1TB WD
      G: 500GB WD
      I added one 120GB SSD and changed drive letters as follows:
      C: OS  320GB WD
      D: CD-writer
      E: Export 1TB WD
      M: Media 500GB WD
      S: Scratch 120GB SanDisk SSD
      My system is:
      Windows 7 Ultimate 64bit
      i5-2320 3.00GHz
      32GB memory
      Radeon HD 7770-OC
      Diablotek 675 watt PSU
      ASRock H77 Pro4/MVP motherboard
      The original install came from a download purchase on Amazon. It is working perfectly on my laptop and was working here also. PrE11 settings were all default. Everything was pointing to the C: drive as usual after installation. After installing the new drive and changing the letters of others (with the exception of the C: drive), I pointed the "Libraries" (Documents, Music, Pictures and Video) of the only user/administrator on the PC to the 1TB Export drive. I also pointed the "Downloads" folder to that same 1TB drive.
      I have tried both .exe files in the "C:\Program Files\Adobe\Adobe Premiere Elements 11" folder. I have uninstalled once and reinstalled twice. There are no error messages. PrE11 is NOT running in the Applications tab or the Processes tab of Windows Task Manager.
