2 Replies Latest reply on May 22, 2013 12:02 AM by Hmmokthen
    Colour Space in Camera Raw
    Hmmokthen Level 1
      Hi, Im new to Camera Raw. You can choose the colour space that your file will open up in photoshop as eg. adobergb or srgb. However when you select the colour space does it also ultimately affect what colours you are working with in camera raw? As you can make adjustments to the image like exposure but if it uses srgb that has fewer colours than adobe rgb then you wouldnt be able to see all the colours that your are affecting with the changes you make in Camera Raw. Any help is appreciated. thanks
        • 1. Re: Colour Space in Camera Raw
          RASouthworth Level 3
          Welcome to Color Management 101!  Your are essentially correct, although the problem is deeper than you describe.
          The best way to look at it is as three sided, i.e. the profiles associated with the image, display, and printer, with the CMS (Color Management System) inside Photoshop as the traffic cop.  The rendering space you choose within ACR will define the color gamut boundary of the image, with sRGB the smallest, Adobe1998 in the middle, and ProPhoto the largest (forgetting the fourth choice Colormatch since it is of no practical value to most of us).  For this reason many of us choose ProPhoto in order to not limit the editing range.
          However the display profile will usually limit the colors you can see regardless of the chosen image rendering space, since the gamut of most displays is less than sRGB.  You can still measure the colors with the eyedropper, but those outside of the display gamut will be visually clipped to the closest available inside the gamut.  A good example is the bright yellow of some flowers, even though you can measure color differences across a petal the display will render only one shade.  For this reason if the image is destined only for email/web viewing sRGB is the best colorspace choice, since an image in ProPhoto space will look very flat and unsaturated on non-color managed systems.
          There is a lot more to the subject, particularly when you factor in printing, since many printers will render colors outside of the display gamut, sometimes tough to visualize the final print from the display rendering.  Many books exist on the subject, time to start Googling.
          Richard Southworth
          • 2. Re: Colour Space in Camera Raw
            Hmmokthen Level 1
            thanks for the reply
