6 Replies Latest reply on May 22, 2013 6:19 AM by PawanChillar
    Configure dispatcher on ubuntu
    PawanChillar
      Am not able to get dispatcher working on my Ubuntu machine, following is the error that I get after apache restart
      Syntax error on line 2 of /etc/apache2/conf.d/dispatcher.any:
      Invalid command '/farms', perhaps misspelled or defined by a module not included in the server configuration
      Action 'configtest' failed.
      Am using the default dispatcher.any file without any changes.
      I've enabled the dispatcher module as below:
      LoadModule dispatcher_module /usr/lib/apache2/modules/dispatcher-apache2.2-4.1.4.so
      <IfModule disp_apache2.c>
              # location of the configuration file. eg: 'conf/dispatcher.any'
              DispatcherConfig conf.d/dispatcher.any
              # location of the dispatcher log file. eg: 'logs/dispatcher.log'
              DispatcherLog    /var/log/apache2/dispatcher.log
              # log level for the dispatcher log
              # 0 Errors
              # 1 Warnings
              # 2 Infos
              # 3 Debug
              DispatcherLogLevel 3
              # if turned to 1, the dispatcher looks like a normal module
              DispatcherNoServerHeader 0
              # if turned to 1, request to / are not handled by the dispatcher
              # use the mod_alias then for the correct mapping
              DispatcherDeclineRoot 0
              # if turned to 1, the dispatcher uses the URL already processed
              # by handlers preceeding the dispatcher (i.e. mod_rewrite)
              # instead of the original one passed to the web server.
              DispatcherUseProcessedURL 0
              # if turned to 1, the dispatcher does not spool an error
              # response to the client (where the status code is greater
              # or equal than 400), but passes the status code to
              # Apache, which e.g. allows an ErrorDocument directive
              # to process such a status code.
              DispatcherPassError 0
      </IfModule>
      Can anyone please help me out in resolving the issue?
      -- Pawan
        • 1. Re: Configure dispatcher on ubuntu
          Ove Lindström Level 4
          How does your dispatcher.any file look like?
          What is the encoding of that file?
          • 2. Re: Configure dispatcher on ubuntu
            PawanChillar Level 1
            Ove,
            The encoding is "text/plain; charset=us-ascii" and following is the content:
            # Each farm configures a set of load balanced renders (i.e. remote servers)
            /farms
              # First farm entry
              /website
                # Request headers that should be forwarded to the remote server.
                /clientheaders
                  # Forward all request headers that are end-to-end. If you want
                  # to forward a specific set of headers, you'll have to list
                  # them here.
                # Hostname globbing for farm selection (virtual domain addressing)
                /virtualhosts
                  # Entries will be compared against the "Host" request header
                  # and an optional request URL prefix.
                  # Examples:
                  #   www.company.com
                  #   intranet.*
                  #   myhost:8888/mysite
                # The load will be balanced among these render instances
                /renders
                  /rend01
                    # Hostname or IP of the render
                    /hostname "127.0.0.1"
                    # Port of the render
                    /port "8080"
                    # Connect timeout in milliseconds, 0 to wait indefinitely
                    # /timeout "0"
                # The filter section defines the requests that should be handled by the dispatcher.
                # The globs will be compared against the request line, e.g. "GET /index.html HTTP/1.1".
                /filter
                  # Deny everything first and then allow specific entries
                  /0001 { /type "deny"  /glob "*" }
                  # Open consoles
            #     /0011 { /type "allow" /glob "* /admin/*"  }  # allow servlet engine admin
            #     /0012 { /type "allow" /glob "* /crx/*"    }  # allow content repository
            #     /0013 { /type "allow" /glob "* /system/*" }  # allow OSGi console
                  # Allow non-public content directories
            #     /0021 { /type "allow" /glob "* /apps/*"   }  # allow apps access
            #     /0022 { /type "allow" /glob "* /bin/*"    }
                  /0023 { /type "allow" /glob "* /content*" }  # disable this rule to allow mapped content only
            #     /0024 { /type "allow" /glob "* /libs/*"   }
            #     /0025 { /type "deny"  /glob "* /libs/shindig/proxy*" } # if you enable /libs close access to proxy
            #     /0026 { /type "allow" /glob "* /home/*"   }
            #     /0027 { /type "allow" /glob "* /tmp/*"    }
            #     /0028 { /type "allow" /glob "* /var/*"    }
                  # Enable specific mime types in non-public content directories
                  /0041 { /type "allow" /glob "* *.css *"   }  # enable css
                  /0042 { /type "allow" /glob "* *.gif *"   }  # enable gifs
                  /0043 { /type "allow" /glob "* *.ico *"   }  # enable icos
                  /0044 { /type "allow" /glob "* *.js *"    }  # enable javascript
                  /0045 { /type "allow" /glob "* *.png *"   }  # enable png
                  /0046 { /type "allow" /glob "* *.swf *"   }  # enable flash
                  /0047 { /type "allow" /glob "* *.jpg *"   }  # enable jpg
                  /0048 { /type "allow" /glob "* *.jpeg *"  }  # enable jpeg
                  # Enable features
                  /0062 { /type "allow" /glob "* /libs/cq/personalization/*"  }  # enable personalization
                  # Deny content grabbing
                  /0081 { /type "deny"  /glob "GET *.infinity.json*" }
                  /0082 { /type "deny"  /glob "GET *.tidy.json*"     }
                  /0083 { /type "deny"  /glob "GET *.sysview.xml*"   }
                  /0084 { /type "deny"  /glob "GET *.docview.json*"  }
                  /0085 { /type "deny"  /glob "GET *.docview.xml*"  }
                  /0086 { /type "deny"  /glob "GET *.*[0-9].json*" }
            #     /0087 { /type "allow" /glob "GET *.1.json*" }          # allow one-level json requests
                  # Deny query
                  /0090 { /type "deny"  /glob "* *.query.json*" }
                # The cache section regulates what responses will be cached and where.
                /cache
                  # The docroot must be equal to the document root of the webserver. The
                  # dispatcher will store files relative to this directory and subsequent
                  # requests may be "declined" by the dispatcher, allowing the webserver
                  # to deliver them just like static files.
                  /docroot "/opt/communique/dispatcher/cache"
                  # Sets the level upto which files named ".stat" will be created in the
                  # document root of the webserver. When an activation request for some
                  # page is received, only files within the same subtree are affected
                  # by the invalidation.
                  #/statfileslevel "0"
                  # Flag indicating whether to cache responses to requests that contain
                  # authorization information.
                  #/allowAuthorized "0"
                  # Flag indicating whether the dispatcher should serve stale content if
                  # no remote server is available.
                  #/serveStaleOnError "0"
                  # The rules section defines what responses should be cached based on
                  # the requested URL. Please note that only the following requests can
                  # lead to cacheable responses:
                  # - HTTP method is GET
                  # - URL has an extension
                  # - Request has no query string
                  # - Request has no "Authorization" header (unless allowAuthorized is 1)
                  /rules
                    /0000
                      # the globbing pattern to be compared against the url
                      # example: *             -> everything
                      #        : /foo/bar.*    -> only the /foo/bar documents
                      #        : /foo/bar/*    -> all pages below /foo/bar
                      #        : /foo/bar[./]* -> all pages below and /foo/bar itself
                      #        : *.html        -> all .html files
                      /glob "*"
                      /type "allow"
                  # The invalidate section defines the pages that are "invalidated" after
                  # any activation. Please note that the activated page itself and all
                  # related documents are flushed on an modification. For example: if the
                  # page /foo/bar is activated, all /foo/bar.* files are removed from the
                  # cache.
                  /invalidate
                    /0000
                      /glob "*"
                      /type "deny"
                    /0001
                      # Consider all HTML files stale after an activation.
                      /glob "*.html"
                      /type "allow"
                    /0002
                      /glob "/etc/segmentation.segment.js"
                      /type "allow"
                    /0003
                      /glob "*/analytics.sitecatalyst.js"
                      /type "allow"
                  # The allowedClients section restricts the client IP addresses that are
                  # allowed to issue activation requests.
                  /allowedClients
                    # Uncomment the following to restrict activation requests to originate
                    # from "localhost" only.
                    #/0000
                    #  /glob "*"
                    #  /type "deny"
                    #/0001
                    #  /glob "127.0.0.1"
                    #  /type "allow"
                  # The ignoreUrlParams section contains query string parameter names that
                  # should be ignored when determining whether some request's output can be
                  # cached or delivered from cache.
                  # In this example configuration, the "q" parameter will be ignored.
                  #/ignoreUrlParams
                  #  /0001 { /glob "*" /type "deny" }
                  #  /0002 { /glob "q" /type "allow" }
                # The statistics sections dictates how the load should be balanced among the
                # renders according to the media-type.
                /statistics
                  /categories
                    /html
                      /glob "*.html"
                    /others
                      /glob "*"
            • 3. Re: Configure dispatcher on ubuntu
              Kristian Wright Level 1
              Ensure that all your { and  } match up, as this will cause issues otherwise.
              • 4. Re: Configure dispatcher on ubuntu
                KWright, the curly braces are matching properly. Anything else that you might cause the issue?
                • 5. Re: Configure dispatcher on ubuntu
                  Yes, I just re-read that you're using the default dispatcher.any.
                  The only difference I see in your  apache conf file settings compared to mine is that I'm using the default 'suggested' settings for the location of the dispatcher.any and log files:
                  DispatcherConfig     conf/dispatcher.any
                  DispatcherLog          logs/dispatcher.log
                  Apart from that, I don't see anything different to what I'm running.
                  K
                  • 6. Re: Configure dispatcher on ubuntu
                    KWright,
                    I changed the location of dispatcher.any and log file and it seemed to work It's weird!!!
                    Thanks for your time mate!
