1 Reply Latest reply on May 22, 2013 11:42 AM by John Hall
    Loading symbols into reusable container
    John Hall Level 4
      Those who are active on the list today can watch me build my slide show program step by step ;-). So I have symbols loading into containers with the intent to fade between two containers. This all works fine for the first two slides:
            function playNext() {
              currentSlide++;
              var audioID = "slide" + currentSlide;
              playSound(audioID);
              var slideID = "slide_" + currentSlide;
              EC.info("current slide should be " + slideID)
              if (currentSlide % 2 == 0){
                sym.$("slideContainer1").css({opacity:0});
                mySlide = sym.createChildSymbol(slideID, "slideContainer1");
                sym.$("slideContainer1").animate({opacity:1}, 500);
                sym.$("slideContainer2").animate({opacity:0}, 500);
              }else{
                sym.$("slideContainer2").css({opacity:0});
                mySlide = sym.createChildSymbol(slideID, "slideContainer2");
                sym.$("slideContainer2").animate({opacity:1}, 500);
                sym.$("slideContainer1").animate({opacity:0}, 500);
      Ah, but when I load slide 3 into the first container, it still comes up with the slide 1 content. I would at least have expected the slide 3 content to overlay the slide 1 content but it's solely the slide 1 content. Thinking as a Flash programmer, I figure that maybe I need to go in and destroy the children of the container before adding a new symbol to the container.
      Following the API guide, I was expecting to do something along the lines of
      //  var childSymbols = sym.$("slideContainer1").getChildSymbols();
                // for(var i=0; i<childSymbols.length; i++){
                //   childSymbols[i].deleteSymbol();
      then add the new material. However, var childSymbols = sym.$("slideContainer1").getChildSymbols();  results in a generic javascript error in the console. Even if I put the one line
      in the compositionReady script, I get this in the console.
      Javascript error in event handler! Event Type = element
      A couple of questions:
      1. Is there a way to switch out the children of a symbol? I thought it would be straightforward but obviously I don't understand
      2. Do I need to worry about garbage collection in JavaScript like I would in Flash. Do I need to destroy child objects or set them to null before reuse of a container symbol
      3. Can I reuse a container symbol once it's been loaded programmatically once?
      Thanks so much
        • 1. Re: Loading symbols into reusable container
          John Hall Level 4
          OK, so with Tim's leads to another problem I figured it out. The content on the 3rd slide was loading fine but I had not unloaded what was previously in the container. By adding the  line
          sym.$("slideContainer1").children().remove();
          before adding the new content, it worked fine. For those who run into a similar issue in the future, here's code that's working for me. Some, obviously, is specific to my project but it could be helpful to others.
                  currentSlide++;
                  hideMenu();
                  resetMenuControls();
                  playSound(audioID);
                  if (currentSlide % 2 == 0) {
                      opacity: 0
                      opacity: 1
                    }, 500);
                      opacity: 0
                    }, 500);
                  } else {
                    sym.$("slideContainer2").children().remove();
                      opacity: 0
                      opacity: 1
                    }, 500);
                      opacity: 0
                    }, 500);
