1 Reply Latest reply on May 22, 2013 12:44 AM by yingzhou
    Missing Check box responses on download PDF
    pkministrywebs
      I see the check box results in the "results table" but I don't see the check boxes "checked" on the downloadable PDF....   any thoughts?
        • 1. Re: Missing Check box responses on download PDF
          yingzhou
          I'm not clear what operation you want to do. I guess you said  "I see the check box results in the "results table" - that means you see the check box marked "checked" in View Responses tab. Right?
          And you said "I don't see the check boxes "checked" on the downloadable PDF...." - please confirm where you generated the downloadable PDF, by using "Save Submission-Enabled PDF" in Distribute tab or  by using "Download Response as PDF Form..." in View Responses tab?
          Ying
