3 Replies Latest reply: May 23, 2013 11:13 AM by GKaiseril RSS
    Show/Hide Form Fields
    lmphil Community Member
      Thanks in advance for your help. I am working with a form that contains calculated fields. The calculated field is formatted for currency, so it contains the "$ 0.00" in the field automatically. Customers may also print out this form and fill it in by hand, so the "$ 0.00" is a nuisance. Is there any way that I can hide the calculated field unless the user actually enters data in the fields to be calculated? Any advice would be appreciated. Thanks.
        • 1. Re: Show/Hide Form Fields
          GKaiseril CommunityMVP
          The us of the currency symbol does not allow the suppression of the zero display with a null string. So you can either set the fields not use the currency symbol or dynamically change the field format with JavaScript.
          For the validation script use the following code:
          // custom validation code;
          var cCurrency = ""; // clear currency symbol;
          if(event.value != 0) {
          event.value = event.value;
          // set currency symbol to USD
          cCurrency = "$";
          } else {
          // zero value set field value to the null
          event.value = "";
          // set field format with/without currency symbol;
          AFNumber_Format(2, 0, 0, "", cCurrency, true);
          // end custom validation code;
          The number of decimal places is assumed to be 2.
          The form will need to be cleared or a calculation performed so the calculated fields will be updated and the validation script will run before one will see the results of this change.
          • 2. Re: Show/Hide Form Fields
            Thanks! Does that also work in the case of a "%"?
            • 3. Re: Show/Hide Form Fields
              One would need to use the AFPercent_Format with the correct parameters.
              AFNumberFormat help
