• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
error invoking cfc: internal server error
Explorer ,
Oct 22, 2007 Oct 22, 2007
I can't be the only one on earth with this error/problem. I have 2 pieces of code that are essentially the same. One works and one produces the error "error invoking cfc....:internal server error".
TOPICS
Advanced techniques
Views
872
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Oct 23, 2007 Oct 23, 2007
"Essentially the same" or "the same"?
It's hard to tell, based only on your description, which is a bit light
weight.
Any chance of posting both the calling code and the relevant parts of the
CFC?
What CF version are you on (both environments).
What is different between the two environments?
Adam
Votes
Translate
Translate
Report
Report
Advocate ,
Try putting '?cfdebug' in your URL and see what the debug log window says.
Votes
Translate
Translate
Report
Report
Explorer ,
Oct 25, 2007 Oct 25, 2007
10/15/2007 07:50:13 PM
Reply | Quote | Top | Bottom | Edit
I'm a little frustrated with CF8 and the new Spry functions. I'm trying to convert my old autosuggests to the cfinput and binding with a function in a cfc. I'm trying to follow the examples but getting the following error;
Error invoking CFC /components/tsijobads cfc. Internal server error (enable debugging .......)
The code is;
<cffunction name="getCompanies" access="remote" returntype="array" output="false" description="Returns submission titles">
<cfargument name="term" type="string" required="true">
<cfset var CnameQry = "">
<cfquery name="CnameQry" datasource="AS400" dbtype="ODBC" maxrows="50">
SELECT rtrim(ltrim(csnam1)) as cname, rtrim(ltrim(csstat)) as state, rtrim(ltrim(cscity)) as city, csrec## as companyid
FROM cstatic
WHERE UPPER(csnam1) LIKE <cfqueryparam cfsqltype="cf_sql_varchar" value="#ucase(left(arguments.term,255))#%">
order by csnam1,cscity
</cfquery>
<!--- Build result array --->
<cfset Carray = listotarray(CnameAry.csnam1)>
<cfreturn Carray>
</cffunction>
<cfinput name="sfCname#counter#" id="sfCname#counter#" autosuggest="cfc:400comps.tsijobads.getCompanies({cfautosuggestvalue})" maxResultsDisplay="50">
Votes
Translate
Translate
Report
Report
Explorer ,
10/16/2007 02:38:54 AM
> debugging .......)
your error says your cfc is in /components/tsijobads
your cfinput bind says it is in 400comps.tsijobads
either on of them is a typo or you are trying to use a mapped cf folder,
which is not allowed with ajax calls.
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com
Votes
Translate
Translate
Report
Report
Explorer ,
10/16/2007 03:50:57 PM
This code works;
<cfinput name="sfCname#counter#" id="sfCname#counter#" size="40" autosuggest="cfc:400comps.tsijobads.getCompanies({cfautosuggestvalue})" maxResultsDisplay="50">
<cffunction name="getCompanies" access="remote" returntype="string">
<cfargument name="term" type="any" required="false" default="">
FROM cstatic
</cfquery>
<cfreturn ValueList(CnameQry.cname)>
</cffunction>
This code does not;
<cfinput type="text" name="sfiname#counter#" id="sfiname#counter#" autosuggest="cfc:400comps.tsijobads.getIndividualsH({cfautosuggestvalue})" maxResultsDisplay="50">
<cffunction name="getIndividualsH" access="remote" returntype="string">
<cfset var IndivQry = "">
<cfquery name="IndivQry" datasource="AS400" dbtype="ODBC" maxrows="50">
SELECT rtrim(ltrim(isfnam)) as FNAME, rtrim(ltrim(islnam)) as LNAME, rtrim(ltrim(istitl)) as ITITLE, iswfon as WPHONE, isrec## as RECNUM
FROM istatic
WHERE UPPER(islnam) LIKE <cfqueryparam cfsqltype="cf_sql_varchar" value="#ucase(left(arguments.term,255))#%">
ORDER by islnam,isfnam
</cfquery>
<cfreturn ValueList(IndivQry.isfnam)>
</cffunction>
I don't think the mapped folder is the problem. I solved part of the problem by changing the function output type to "string" and returning a list. Some of the examples and cfml ref are just plain wrong. Hard to believe, huh.
I just noticed that I have a type of "text" on one cfinput and not the other. I just tested it without "text" and it didn't make a difference
Votes
Translate
Translate
Report
Report
Explorer ,
LATEST
10/17/2007 03:56:56 PM
Started from scratch using cfinput and autosuggest. It works fine. I just can't find the error in the above code.
Votes
Translate
Translate
Report
Report
Resources
Documentation
