1 Reply Latest reply on May 22, 2013 10:15 AM by dln385
    RegEx Lazy mode bug in CS5
    Marco Lugli
      Hello, it seems that sometimes, lazy mode regex doesn't work in CS5.
      Following this discussion: http://forums.adobe.com/message/4007138
      I would like to understand how can I create a regex code for the following cases:
      1
      0,1
      0,10
      0,100
      1,0
      10,0
      100,0
      1.000,00
      10.000,00
      100.000,00
      My first approach was the following:  ((\d+)?(\.?))+(\d{1,3})(,(\d+))?
      Unfortunately, CS5 doesn't seem to work with this part of the code: (\d+)?
      Is there a way to bypass this limitation?  Thanks in advance
        • 1. Re: RegEx Lazy mode bug in CS5
          dln385
          I'm not too sure about the limitations of ExtendScript's implementation of regular expressions, but this regex should work: \d+(\.\d\d\d)*(,\d+)?
          If the problem with (\d+)? is the question mark, you could do (\d+){0,1} instead. If my regex has the same problem, you could use \d+(\.\d\d\d)*(,\d+){0,1} instead.
