1. Re: Why do the answer blocks dissappear when exporting the form to PDF?
Wenlan_Du May 23, 2013 1:34 AM (in response to COLDHEARTED FILMS)Hi,
Do you mean "View Responses" tab by "the answer blocks"? If you do, then the answers are not exported together when you save the form as Submittable PDF forms, which is for users to fill in answers only. If you want to export responses, you will need to do it following steps below:
- Click on View Responses tab
- Click on File -> Export Responses or Download Selected Responses as PDF Form
Then you'll have an excal or PDF file with all responses or PDF forms with responses filled out.
Wenlan
2. Re: Why do the answer blocks dissappear when exporting the form to PDF?
COLDHEARTED FILMS May 23, 2013 8:09 AM (in response to Wenlan_Du)Hi,
I mean the squares. If want to make a hardcopy PDF version (not connected
with the internet), the sections to answer the question are blank. Right
now, I have to import into photoshop and create a block that's similar to
the example below:
3. Re: Why do the answer blocks dissappear when exporting the form to PDF?
Genevieve Laroche May 23, 2013 3:27 PM (in response to COLDHEARTED FILMS)Your "exemple below" is missing.
Are you generating the form in FormsCentral and then exporting to PDF?
Are you using Adobe Acrobat or Adobe Reader to view the form?
Gen
