0 Replies Latest reply on May 23, 2013 8:01 AM by CloudeKevins
    Is " [error] 1223 1056" a code for "no new Flash Player version available"?
    CloudeKevins
      When I look at the %WINDIR%\System32\Macromed\Flash\FlashInstall.log
      I see that there are a lot of lines that says [error] 1223 1056
      which seems to be coming at 25-hour intervals.
      Here is a paste from the end:
      2013-4-19+14-46-0.218 [error] 1223 1056
      2013-4-20+15-46-0.219 [error] 1223 1056
      2013-4-21+16-46-0.220 [error] 1223 1056
      2013-4-22+17-46-0.219 [error] 1223 1056
      2013-4-25+20-46-0.229 [error] 1223 1056
      2013-4-26+21-46-0.224 [error] 1223 1056
      2013-4-30+0-46-0.221 [error] 1223 1056
      2013-5-1+1-46-0.219 [error] 1223 1056
      2013-5-3+5-46-0.218 [error] 1223 1056
      2013-5-4+6-46-0.218 [error] 1223 1056
      2013-5-9+14-46-0.218 [error] 1223 1056
      2013-5-11+18-46-0.219 [error] 1223 1056
      2013-5-12+19-46-0.218 [error] 1223 1056
      2013-5-13+20-46-0.218 [error] 1223 1056
      2013-5-14+21-46-0.219 [error] 1223 1056
      2013-5-14+21-46-30.663 [error] 1226 1062
      ?=O====== M/11.7.700.202 2013-05-14+21-46-18.196 ========
      0000 [I] 00000010 FlashPlayerInstaller.exe -install -iv 11
      0001 [I] 00000011 1
      0002 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
      0003 [I] 00000013 C:\Windows\TEMP\{B898057E-710A-4C33-A2F4-40D039CD76B5}\Flash32_11_7_700_202.ocx
      0004 [I] 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.exe
      0005 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.exe
      0006 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.dll
      0007 [I] 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
      0008 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
      0009 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
      0010 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
      0011 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
      0012 [W] 00001106
      0013 [W] 00001106
      0014 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
      0015 [I] 00000012
      =X====== M/11.7.700.202 2013-05-14+21-46-32.513 ========
      2013-5-15+8-47-11.891 [error] 1226 1062
      ?=O====== M/11.7.700.202 2013-05-15+08-46-08.567 ========
      0001 [I] 00000011 1
      0003 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
      0004 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
      0005 [W] 00001036 Software\Mozilla\Mozilla Thunderbird\extensions/Plugins 2
      0006 [W] 00001036 Software\Mozilla\Thunderbird\extensions/Plugins 2
      0007 [W] 00001036 Software\Opera Software/Last CommandLine 2
      0008 [W] 00001036 Software\Opera Software/Last CommandLine 2
      0009 [W] 00001036 Software\Opera Software/Plugin Path 2
      0010 [W] 00001036 Software\Opera Software/Plugin Path 2
      0011 [I] 00000014 C:\Windows\TEMP\{17316F58-F619-46CF-8C65-B14CF1AFD71B}\NPSWF32_11_7_700_202.dll
      0012 [I] 00000025 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_202_Plugin.exe
      0013 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_202_Plugin.exe
      0014 [I] 00000024 C:\Windows\SysWOW64\Macromed\Flash\plugin.vch
      0015 [I] 00000017 C:\Windows\SysWOW64\Macromed\Flash
      0016 [I] 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_11_7_700_202.exe
      0017 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
      0018 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
      0019 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
      0020 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
      0021 [W] 00001106
      0022 [W] 00001106
      0023 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
      0024 [I] 00000012
      =X====== M/11.7.700.202 2013-05-15+08-47-13.787 ========
      2013-5-16+10-46-0.218 [error] 1223 1056
      2013-5-17+11-46-0.218 [error] 1223 1056
      2013-5-19+13-46-0.218 [error] 1223 1056
      2013-5-21+15-46-0.218 [error] 1223 1056
      2013-5-22+16-46-0.218 [error] 1223 1056
      I tried to read a bit about the Adobe Flash Player Background Updater, and IIUIC it checks for a new version,
      and if there is none, it will wait 24 hours before checking again. So - about those 25-hour intervals.. maybe
      - it waits 1 hour, checks, then waits 24 hours, checks, then writes an [error] 1223 1056 entry in the log,
      then again waits 1 hour, checks, then waits 24 hours, checks, then writes an [error] 1223 1056 entry in the log, etc etc.
      Sometimes there are a 50-hour interval (e.g. between 2013-5-17+11-46-0.218 and 2013-5-19+13-46-0.218)
      Why no entry at 2013-5-18+12-46-0.218..? My pc was on at that time.
      Other times there are 75-hour intervals - and some, although very rare, are intervals
      that are not a multiple of 25.
      Also, it seems that there is another error code; [error] 1226 1062 - that often appears, like 1 minute after the update process has actually started, e.g.
      My FlashInstall.log dates back to version 10.1.85.3 at 2010-10-11+00-43-40.917,
      and these errors first started to appear between versions 11.2.202.228 and 11.2.202.233..:
      =X====== M/11.2.202.228 2012-04-04+09-54-42.460 ========
      2012-4-9+0-54-0.221 [error] 1223 1056
      2012-4-10+11-54-0.223 [error] 1223 1056
      2012-4-11+22-54-0.135 [error] 1221 1115
      ?=O====== M/11.2.202.233 2012-04-13+21-54-11.056 ========
      As you can see, here it was 35-hour intervals. Between 11.2.202.233 and 11.2.202.235 it became 25-hour (or multiples)
      =X====== M/11.2.202.233 2012-04-13+22-54-47.061 ========
      2012-4-15+0-54-0.220 [error] 1223 1056
      2012-4-17+5-54-0.219 [error] 1223 1056
      2012-4-18+6-54-0.221 [error] 1223 1056
      2012-4-19+7-54-0.219 [error] 1223 1056
      2012-4-23+11-54-0.218 [error] 1223 1056
      2012-4-24+12-54-0.223 [error] 1223 1056
      2012-4-26+14-54-0.219 [error] 1223 1056
      2012-4-27+15-54-0.223 [error] 1223 1056
      2012-4-28+16-54-0.223 [error] 1223 1056
      2012-4-30+17-54-0.224 [error] 1223 1056
      2012-5-5+5-54-0.218 [error] 1223 1056
      2012-5-5+5-54-49.183 [error] 1226 1062
      ?=O====== M/11.2.202.235 2012-05-05+05-54-05.291 ========
      After the installation of version 11.2.202.235, the Windows Task Scheduler was set to the current settings, to start FlashPlayerUpdateService.exe
      daily, start 01.01.2000  01:46:00, recur every 1 days,
      repeat every 1 hour for a duration of 1 day
      =X====== M/11.2.202.235 2012-05-05+06-55-06.588 ========
      2012-5-7+6-28-59.26 [error] 1226 1062
      2012-5-8+8-46-0.219 [error] 1223 1056
      2012-5-10+11-46-0.219 [error] 1223 1056
      2012-5-12+13-46-0.220 [error] 1223 1056
      2012-5-13+14-46-0.219 [error] 1223 1056
      2012-5-15+15-46-0.219 [error] 1223 1056
      2012-5-18+17-46-0.221 [error] 1223 1056
      2012-5-19+18-46-0.221 [error] 1223 1056
      2012-5-26+12-46-0.220 [error] 1223 1056
      2012-5-27+13-46-0.218 [error] 1223 1056
      2012-5-28+14-46-0.218 [error] 1223 1056
      2012-5-30+16-46-0.220 [error] 1223 1056
      2012-6-1+18-46-0.223 [error] 1223 1056
      2012-6-5+22-46-0.223 [error] 1223 1056
      2012-6-10+14-46-0.218 [error] 1223 1056
      2012-6-11+15-46-0.222 [error] 1223 1056
      2012-6-12+16-46-0.218 [error] 1223 1056
      2012-6-13+17-46-0.218 [error] 1223 1056
      2012-6-17+20-46-0.218 [error] 1223 1056
      2012-6-18+21-46-0.218 [error] 1223 1056
      2012-6-23+7-30-6.350 [error] 1226 1062
      ?=O====== M/11.3.300.262 2012-06-23+07-29-47.162 ========
      So - I guess my question might be rephrased to a more general one;
      - is there a list available that explains what these error codes actually mean?
