4 Replies Latest reply on Oct 23, 2007 8:16 AM by Giribabums
    Date substraction
    Giribabums
      I am storing mindate and maxdate in an arraycollection, i want to find number of days between mindate and maxdate.
      How can i achieve this, i have written the following code to retrieve the date from arraycollection.
      [code]
      var tmpStr1:String = oppdata[oppNumber].MinDate; // oppdata is arraycollection
      var tmpStr2:String = oppdata[oppNumber].MaxDate;
      var tmpDate1:Array = tmpStr1.split("-");
      var tmpDate2:Array = tmpStr2.split("-");
      var minDate:Date = new Date(tmpDate[1]+"/"+tmpDate[2]+"/"+tmpDate[0] ); // 'MM/DD/YYYY' format;
      var maxDate:Date = new Date(tmpDate[1]+"/"+tmpDate[2]+"/"+tmpDate[0] ); // 'MM/DD/YYYY' format;
      [/code]
      Regards
      Giribabu
        • 1. Re: Date substraction
          have a look at http://jeff.mxdj.com/dateadd_for_actionscript.htm. The basic idea is to get the difference in msecs (using maxDate.getTime() - minDate.getTime()) and then "process" the result to the unit (e.g. days) you need.
          Uwe
          • 2. Date substraction
            Giribabums Level 1
            Hi Flexu,
            I did it, i forgot to divide the days with the millisecondperday. lateron i realized and changed the code now its working fine. Thanks for your valiable reply
            [code]
            public static const millisecondsPerDay:int = 1000 * 60 * 60 * 24;
            private function myDaysDifference(minDate:Date, maxDate:Date):uint
            // for testing
            // var minDate:Date = new Date(2007,9,23);
            // var maxDate:Date = new Date (2007, 8, 23);
            return Math.ceil(( minDate.getTime() - maxDate.getTime()) / millisecondsPerDay);
            [/code]
            Regards
            Giribabu
            • 3. Re: Date substraction
              Karl_Sigiscar_1971 Level 3
              Here is a useful method I wrote for a project:
              public function getDateOffset(dateStart:Date, dateFinish:Date):Date
              var resultingDate:Date = new Date();
              var timeOffset:uint;
              var numHours:uint;
              var numMinutes:uint;
              var numSeconds:uint;
              timeOffset = dateFinish.getTime() - dateStart.getTime();
              // 1 minute is 60,000 milliseconds
              numHours = Math.floor(timeOffset / 60 / 60000);
              numMinutes = Math.floor((timeOffset - (numHours * 60 * 60000)) / 60000);
              numSeconds = Math.floor((timeOffset - (numHours * 60 * 60000) - (numMinutes * 60000)) / 1000);
              resultingDate.setHours(numHours);
              resultingDate.setMinutes(numMinutes);
              resultingDate.setSeconds(numSeconds);
              return(resultingDate);
              • 4. Re: Date substraction
                Giribabums Level 1
                Hi Karl,
                Thanks for your valuable reply, may be your code will be usefull in feature, you can find the code above marked as answer for my question.
                Regards
                Giribabu
