2 Replies Latest reply on May 23, 2013 1:58 PM by IM_Katie
    Multi-line Variables
    IM_Katie
      Hello,
      I am working on a ~800 page "book"
      I would like to use variables to set the current chapter & section across the top of each page. The issue I'm running into is that InDesign treats the variable as a single character and everything is squished on one line. I was able to get around this by creating a second paragraph style for the second line (max length), the problem with that solution is that if I am not using that second line, I am still getting a space/paragraph/empty line where the variable would be. If I'm not using the variable, I would like that space to close up. Is there anyway to do that?
      Example:
      <variable 1>
      <variable 1b>  (not used)
      <variable 2>
      <variable 2b>
      Results:
      Variable 1
      Variable 2
      Variable 2b
      I though switching to character styles instead would help, but everything remains on one line, even with spaces or other characters between variables. If I add a shift-return between variables, it has the same empty line problem as the paragraph-style-variables.
      UGH!
        • 1. Re: Multi-line Variables
          Basically, you're asking for something that variables cannot do, at least not currently, as you've apparently come to understand already.
          About the only thing I can think of is to add the line break manually where you need it. You can do that more easily in story editor than in layout view.
          • 2. Re: Multi-line Variables
            IM_Katie Level 1
            Thanks for the suggestion. Simialrly/alternatively I guess I could only include the b-level/second line variables only on the sections that need them. I was just hoping it would be a little less manual than this.
