1 Reply Latest reply on Jun 4, 2013 4:01 AM by sivaprasadreddys
    Custom propertie's values are not updated for workflow metadata
    sivaprasadreddys Level 2
      I've a requirement where I need to add and update some properties. to /etc/workflow/instance/<Instancename>/data/metadata node.
      I've two workflow Process steps,
      Process step 1:
          Adds some properties to metadata.
      Process step 2:
          Updates the propertie's values which are added in Process step 1.
      But the issue is update is not working when the node is /etc/workflow/instance/<Instancename>/data/metadata.
      i.e. In the step 1, Properties are added to metadata node but In the step 2 propertie's values are not updated to the same node.
      Here is my process code:
      import java.util.Locale;
      import java.util.StringTokenizer;
      import javax.jcr.Node;
      import javax.jcr.Session;
      import org.apache.felix.scr.annotations.Component;
      import org.apache.felix.scr.annotations.Properties;
      import org.apache.felix.scr.annotations.Property;
      import org.apache.felix.scr.annotations.Reference;
      import org.apache.felix.scr.annotations.Service;
      import org.osgi.framework.Constants;
      import javax.jcr.Value;
      import com.adobe.granite.workflow.WorkflowException;
      import com.adobe.granite.workflow.WorkflowSession;
      import com.adobe.granite.workflow.exec.WorkItem;
      import com.adobe.granite.workflow.metadata.MetaDataMap;
      import com.adobe.granite.workflow.exec.WorkflowProcess;
      import com.adobe.granite.workflow.model.WorkflowModel;
      import org.apache.sling.api.resource.ResourceResolver;
      import org.apache.sling.api.resource.ResourceResolverFactory;
      import org.apache.sling.jcr.resource.JcrResourceUtil;
      import org.apache.sling.api.resource.PersistableValueMap;
      import org.apache.sling.api.resource.PersistenceException;
      import org.apache.sling.api.resource.Resource;
      @Component
      @Service
      @Properties({
             @Property(name = Constants.SERVICE_DESCRIPTION, value = "Test"),
             @Property(name = Constants.SERVICE_VENDOR, value = "Adobe"),
             @Property(name = "process.label", value = "Test 1")})
      public class Test1 implements WorkflowProcess
          @Reference
          private ResourceResolverFactory resourceResolverFactory;
                public void execute(WorkItem workItem, WorkflowSession wfsession, MetaDataMap metadata)
                                    throws WorkflowException {
                          System.out.println("Testing");
              try{
                  ResourceResolver resolver;
                  resolver = resourceResolverFactory.getAdministrativeResourceResolver(null);
                  String instancePath = workItem.getWorkflow().getId();
                  Node instanceNode=null;
                  Session jcrSession = wfsession.adaptTo(Session.class);
                 String payload = (String) workItem.getWorkflowData().getPayload();
                 //instanceNode=JcrResourceUtil.createPath(payload+"/jcr:content", "nt:resource","nt:resource", jcrSession, true);
                                    instanceNode=JcrResourceUtil.createPath(instancePath+"/data/metaData", "nt:resource","nt:resource", jcrSession, true);
                                    System.out.println("Test: instance PAth:"+instanceNode.getPath());
                  Resource resource = resolver.getResource(instanceNode.getPath());
                      if(resource != null)
                          PersistableValueMap valueMap= resource.adaptTo(PersistableValueMap.class);
                          valueMap.put("name", "Rajesh");
                          valueMap.put("id", "A002");
                          valueMap.put("designation","SE");
                          valueMap.save();
                          System.out.println("Name:"+valueMap.get("name"));
                          System.out.println("Id:"+valueMap.get("id"));
                  jcrSession.save();
                  resolver.close();
              }catch(Exception e)
                  System.out.println("Exception:"+e.getMessage());
      The code works fine when the node is payload/jcr:content.
      Note : Process 1 and Process 2 code is same expect the values I'm passing to the PersistableValueMap.
      Any pointers would be more helpful..
      Siva
