7 Replies Latest reply on Oct 24, 2007 5:59 PM by TheScarecrow
    CSS & ColdFusion, replacing DIV content
    TheScarecrow Level 1
      Ok I have a DIV that on rollover of an object it changes position to the mouse pointer. However, I also want it to replace the content of the DIV tag with ColdFusion code. Something like this:
      <cfoutput><img src="../#staffmember.imageName[3]#" align="middle"><span class="style1">
      #staffmember.wName[3]# </span> </cfoutput>
      Does anyone know how to do this? Thanks.
      (current link code):
      <a
      onmouseover="ShowContent('magnify'); return true;"
      onmouseout="HideContent('magnify'); return true;"
      href="java script:ShowContent('magnify')">
      </a>
        • 1. Re: CSS &amp; ColdFusion, replacing DIV content
          WolfShade Level 4
          You didn't include the DIV, itself (unless you're referring to the anchor). But you can use the name of the DIV and innerHTML to change the content.
          <div id="thisDiv">
          nbsp;
          </div>
          <cfoutput>
          <script language="javascript">
          function whatever() {
          thisDiv = getElementById('thisDiv');
          thisDiv.innerHTML = " #content variable name#";
          </script>
          </cfoutput>
          ^_^
          • 2. Re: CSS &amp; ColdFusion, replacing DIV content
            Here would be my new code but it doesnt work. Did i do something wrong?
            <cfoutput>
            function changeContent() {
            magnify = getElementById('magnify');
            magnify.innerHTML = " <img src="../#staffmember.imageName[3]#" align="middle"><span class="normalText">
            #staffmember.wName[3]# </span>";
            </script>
            </cfoutput>
            DIV
            <div id="magnify" style="display:none;
            position:absolute;
            border-style: solid;
            background-color: white;
            padding: 5px;"><cfoutput><img src="../#staffmember.imageName[2]#" align="middle"><span class="normalText">
            #staffmember.wName[2]# </span> </cfoutput> </div>
            • 3. Re: CSS &amp; ColdFusion, replacing DIV content
              WolfShade Level 4
              In the javascript, the line that says:
              Should read:
              magnify = document.getElementById('magnify');
              ^_^
              • 4. Re: CSS &amp; ColdFusion, replacing DIV content
                Strange still doesnt work. Here is updated code.
                <cfoutput>
                magnify.innerHTML = "<img src="../#staffmember.imageName[3]#" align="middle"><span class="normalText">
                </script>
                </cfoutput>
                DIV tag
                <cfoutput><div id="magnify"><img src="../#staffmember.imageName[2]#" align="middle"><span class="normalText">
                #staffmember.wName[2]# </span> </div></cfoutput>
                I have other Javascript on the page is that a problem??
                • 5. Re: CSS &amp; ColdFusion, replacing DIV content
                  WolfShade Level 4
                  Is the javascript on the same page as the CF code? Or is it in a separate .js file?
                  If it's a separate .js file, copy the <script></script> into the same page as the CF page.
                  That's the only thing I can think of. What isn't working? How is it not working? I need some more specifics. JS error messages?
                  ^_^
                  • 6. Re: CSS &amp; ColdFusion, replacing DIV content
                    The javascript is on the same page. it doesnt change the picture or the text in the div on the rollover. The code for the for the rollover is this:
                    <a
                    onmouseover="ShowContent('magnify'); return true; changeContent();"
                    onClick="HideContent('magnify');"
                    href="staffmember.cfm?EmployeeID=2"><img src="../staff_pictures/thumb/tn_mckee.jpg" width="43" height="60" border="0"></a>
                    • 7. Re: CSS &amp; ColdFusion, replacing DIV content
                      ok if I have say seven pictures and I want the content of the DIV tag to change differently with each of the pictures. So I guess the code would be something like this.
                      Button Code:
                      <a
                      onmouseover="ShowContent('magnify'); return true; changeContent(2);"
                      The Javascript would be:
                      <cfoutput>
                      function changeContent(i) {
                      magnify.innerHTML = "<img src="../#staffmember.imageName #" align="middle"><span class="normalText">
                      #staffmember.wName
                      # </span>";
                      </script>
                      </cfoutput>
                      The DIV tag would be:
                      unfortunately the i is not defined. I am not sure that I can do this without Ajax or doing individual layers for each picture. That do you think?
