1. Re: Ongoing Artboard Bug - Artwork Shifts
Mike Gondek2 May 24, 2013 9:58 AM (in response to Doug Ridgway)Are you sure if you select all in the Transform palette >> align to pixel grid is off, along with the Transform palette flyout >> align new objects to pixel grid is off?
Try Artboards flyout menu >> Duplicate Artboard when having this problem
2. Re: Ongoing Artboard Bug - Artwork Shifts
Doug Ridgway May 29, 2013 1:37 PM (in response to Mike Gondek2)A little more information — I don't typicall use the flyout menu to duplicate.... however, I've noticed today that it's also happening when I shift-constrain moving an artboard with the artboard tool.
3. Re: Ongoing Artboard Bug - Artwork Shifts
Neeraj N Jul 28, 2013 10:31 PM (in response to Doug Ridgway)With the help of files provided by Doug, Ai team has identified the issue and plans to fix it at the earliest. The reason looks to be a combination of selection and speed of drag.
So here is an exmaple of the scenario:
1. Multiple Artboards in the document.
2. In Artboard editing mode, the active artboard is selected.
3. A non-active (non selected) artboard is moved or duplicated at some speed.
The issue is more frequent when working with tables
Workaround:
1. Select the desired artboard.
2. Move or duplicate it at a slow speed.
Thanks!
