1 Reply Latest reply on May 26, 2013 2:25 AM by pixxxel schubser
    Looking for localize names of script folders
    Damienned Level 1
      Hi, i'm trying to get a list of all the scriptfolder names.
      This will solve path issues with other language versions of illustrator.
      My script for now:
      scriptfolder = {
      en: "Scripts",
      nl: "Scripts",
      de: "Skripten"
      var imageiconprinter = File(app.path+'/Presets.localized/' + app.locale + '/'+localize(scriptfolder)+'/idatabase/Images/Infopanel_heinerich/heinerichinfopanelprint er.png');
      I've defined a country like de: which is german and put the correct foldername behind it.
      I would love to have a list of all countrys.
      if you don't have a list just fill in the foldername and countryname of your country.
      Daniel
        • 1. Re: Looking for localize names of script folders
          pixxxel schubser MVP & Adobe Community Professional
          Perhaps this helps a little bit. It is language-independent and shows the path (or the name) to the corresponding scripts folder completly.
          #target Illustrator
          // at first save this script and than run
          var fo = File($.fileName).parent.fsName; //path to scripts folder
          //var fo = File($.fileName).parent.name; // the name of scripts folder
          alert (fo)
          The result should always display the folder where the script is stored.
