9 Replies Latest reply on May 26, 2013 10:58 AM by AffordableParalegal
    Error in Javascript
    AffordableParalegal
      Capture 12.PNGCode that is causing problem is in first field of the form below TOTAL, called "TSM"
      This is the error:  Syntax error: missing ) before condition 9 at line 8
      This is a link to a usable form (I think)  https://workspaces.acrobat.com/?d=eHgoPUbA1ZDY0TyH3CcHRQ
      This is the code
      var c = this.getField("TM")                                         //Gets total mileage from field "TM"
      var d = this.getField("StandardCost")                        //Gets dollar amount from "StandardCost"
      var e = this.getField("Cb")                                         //Gets value of Checkbox
      if ((event.e.value = No)||(event.d.value!=0)){            //If the Checkbox is not checked and there the fee is greater than zero; Mileage X cost = "TSM"
      event.value =c.value * d.value;
          else if{
            ((event.e.value = No)||(event.d.value=0)){           // if the fee is zero and Checkbox is not checked there is no value
                  event.value = "";
          else if{
      (event.e.value = Yes) {                                              //If the checkbox is checked the TSM field is not visible.
                  TSM.hidden = true;
        • 1. Re: Error in Javascript
          If "Yes" and "No" are string values they should be in quotes.
          "true" and "false" are logical system variable so they are not quoted.
          Unchekced check boxes and radio buttons in Acrobat forms have a value of "Off".
          • 2. Re: Error in Javascript
            In addition to George's comments: To compare two values you must use the comparison operator ("=="), not the assignment operator ("=").
            Also, there's no such object as "event.e" and you're missing a closing parenthesis (as the error message suggests).
            • 3. Re: Error in Javascript
              AffordableParalegal Level 1
              I agree as to the "event.e" - that was an experiment and although no errors are generated because of it, it is not correct syntax.
              As to other remarks, not so sure.
              The misuse of brackets was the problem.
              This code generates no error
              if ((e.value = "yes")||(d.value!=0)){
              event.value = (c.value * d.value);
              }                                                    // needed this bracket
                        else if
                          ((e.value = "yes")||(d.value=0))
                                event.value = "";
                        else if
              (e.value = "no") {
                                            TSM.hidden = true
              • 4. Re: Error in Javascript
                This is VERY wrong as noted in reply#2. It is not a syntax error, it just doesn't do what you want.
                • 5. Re: Error in Javascript
                  Well, you should heed the advice given to you... Until you fix all of the issues mentioned above, your code is not going to work correctly.
                  • 6. Re: Error in Javascript
                    agree; I am past the syntax error and now working on problems.
                    • 7. Re: Error in Javascript
                      Made changes as follows but still not getting form fields to be not visible. Does display.hidden apply only to text fields and not number fields?
                      Getting ahead of myself a bit but the next problem I need to work on is to add condition for when mileage calculation is changed to automatically change price. I am wondering if this is a condition better made on a document level instead of object level?
                      if ((e.value = "Yes")&&(d.value!=0)){
                      event.value = c.value * d.value;
                                else if
                                  ((e.value = "Yes")&&(d.value=0))
                                        event.value = "";
                                else if
                      (e.value != "Yes") {
                                                    getField("TSM").display = display.hidden
                                                    getField("FC").display = display.hidden
                                                    getField("SC").display = display.hidden
                                                    getField("M1").display = display.hidden
                                                    getField("M2").display = display.hidden
                      }else{
                                                    getField("TSM").display = display.visible
                                                    getField("FC").display = display.visible
                                                    getField("SC").display = display.visible
                                                    getField("M1").display = display.visible
                                                    getField("M2").display = display.visible
                      • 8. Re: Error in Javascript
                        You did not fix the use of the assignment operator in your if-statements, which was pointed out twice.
                        And the display property applies to all fields.
                        • 9. Re: Error in Javascript
                          if you mean logical operators, I changed them and the code works fine. Thanks.
