6 Replies Latest reply on May 26, 2013 7:58 PM by Jim_Simon
    Big Problems with PP -> AE -> Encore MPEG2-DVD export
    President Beeblebrox Level 1
      Hey guys & gals
      For the last two days I have pretty much torn the remaining hair from my scalp...
      I have a 190 minute 1920x1080 25p Video, all prepared in Premiere Pro.
      The Video has ONE audio track and THREE video tracks.
      Each of the Video tracks has some transitions (in my case: Roll Away (page peel)).
      One of the vids is the main video, the two others should appear in Picture-in-Picture Frames created with After Effects.
      The end result should then be rendered to MPEG2-DVD and a DVD created with Encore.
      Here are my two (?) problems.
      Problem 1: Premiere Pro & After Effects
      - When replacing my nested sequences (each video track is its own nest) and send it to AE all seems well.
      - However: None of my transitions will render out of AE (basically clip 1 cuts right away to clip 2 without the transition)
      Problem 2: MPEG2-DVD export - sound is too short
      - When I render my footage to MPEG2-DVD using AME, the sound is always too short.
      - Example: I got a 24 min chapter and the sound only lasts around 23 minutes. Then it just goes silent while the rest of the video plays.
      - (I multiplexed the sound into the MPEG2 file).
      Possible Solution?
      I have tried so many things already... Now I am thinking about this:
      Is this a solution for #1?:
      - export every video track separately and lossless (Windows Media, 1920x1080 25p ?)
      - export the sound sound track as AAC sound.
      - Create a new timeline with the newly rendered (have all transitions in them) videos.
      - THEN send them to AE again. AE does its thing.
      For Problem #2 (sound too short) I have no idea right now. That is the most vexing of my problems.
      Any help would be greatly appreciated.
      Regards from Berlin,
        • 1. Re: Big Problems with PP -> AE -> Encore MPEG2-DVD export
          tfi productions 44 Level 1
          hello,  to get you going you probably want to post back with:
          system specs
          which adobe version you are using
          the part i can help with is you should NOT mux together audio and video
          when exporting the mpeg2-dvd:  you should use the mpeg2-dvd preset
          and render out separare audio file and video file
          you will need to load them separately into Encore on the timeline
          (i'm not sure if this will fix the shortened audio, but other more wiser users
          will posit this as a step in the right direction)
          one thing to try would be to load the project into AME
          set up the separate files to be encoded via the mpeg2dvd preset
          tweak if necessary
          AND THEN select the last 5 minutes of your timeline to export
          to see if the shortened audio is fixed
          (i learned to export small pieces of projects checking for quality
          while doing a 85 minute timeline from 1920x1080 to mpeg2 recently)
          hope this gets you started, j
          • 2. Re: Big Problems with PP -> AE -> Encore MPEG2-DVD export
            See my reply to your Encore posting http://forums.adobe.com/thread/1219857
            Multiplexing video and sound is only for computer playback, not for DVD authoring
            • 3. Re: Big Problems with PP -> AE -> Encore MPEG2-DVD export
              Thanks John & tfi for clearing up the audio/video issue!
              I will try that now - I am confident your advise works!
              As far as my system is concerned: Pretty fast i7 with multiple disks, Software is Creative Cloud Subscription (so all should be up-to-date).
              Maybe I don't get this whole Premiere / After Effects combo. I am a PPro advanced user, but an absolute AE noob
              So: I have a sequence in PPro. It has all kinds of transition effects in there, such as the "roll away" page peel.
              When I replace the sequence with an AE comp, I lose my transitions. In AE it shows all of the effects, such as 'roll away' between the clips, but they all have 0 duration.
              AE cuts from one clip to another without the transition.
              I hope I don't have to render my three videos out to lossless WMF or something and then put them in AE. In total, I have 6 disks with 90 chapters to go. That would be 270 exports before I can even begin working in AE...
              Again, thanks guys! And more help is even more appreciated
              • 4. Re: Big Problems with PP -> AE -> Encore MPEG2-DVD export
                In the meantime I found the very unsatisfying answer to my first problem:
                Transitions in PPro are not available in AE - except for the cross disolve...
                That is very sad but can't be helped it seems. Worst case I will go to cross dissolve, but that is not really what I need.
                Does anyone know whether there are 3rd party transitions that work both in PPro and AE? I understand that the model those two programs use are very different, I am just trying to find a solution that will avoid me having to export 270 lossless sequences just to be able to keep my precious transitions
                Thanks again for all your help!
                • 5. Re: Big Problems with PP -> AE -> Encore MPEG2-DVD export
                  at this point i suggest you create a thread in the AE forum as well
                  asking for help
                  here is some dated 2009 info re: AE and PPRO
                  is it possible to eliminate AE from the equation by doing your picture in picture in premiere
                  by resizing the videos?
                  this way you can keep your transitions....
                  cheers, j
                  • 6. Re: Big Problems with PP -> AE -> Encore MPEG2-DVD export
                    Jim_Simon Level 8
                    AE does its thing.
                    What exactly is it's 'thing' in this case?  Why are you sending everything to AE?
