1 Reply Latest reply on May 27, 2013 3:57 AM by try67
    Output to form
    Durbslaw
      Hi All,
      I would like the following code snippet to display its result on a text box on my form.
      if (global.count == null) {
      global.count = 1000000
      global.setPersistent("count",true)
      else
      global.count++
      var f = this.getField("jobCount")
      f.value = global.count
      I am using acrobat professional 9.0.0 and the Advanced>Document processing>Document JavaScript as well as the Edit All JavaScript options are disabled (grayed out).
      Could I please have a list of steps, if the above objective is achievable....THANKS!!!!
        • 1. Re: Output to form
          If sounds like you form is either secured, has the Reader Rights applied to
          it or was created in LiveCycle Designer... Either way, you can't edit it
          like that.
          If it's secured you have to remove the security settings to allow you to
          edit it.
          If it has the Reader Rights save a copy to remove them.
          If it's a LCD form you have to edit it there, and this code will not work.
