31 Replies Latest reply on Aug 28, 2008 11:59 AM by Peter Grainge
    Available Conditional Build Tag Expressions
    raynerts
      I'm part of a team that works on a version control project that encompasses content across numerous business lines with a lot of shared content between them. This means that we use conditional tags quite a bit. I'm new to the group and have been playing around with the tags in the topic, previewing it, and then experimenting with different tag expressions to see what is made invisible and what remains.
      But now, all of the tag expressions that I defined in the preview window while messing around are still present and I can't remove them. All of the new expressions really crowd out the standard set we use for legitimate testing and I just know this is going to piss my co-workers off.
      Please, any help you can provide in undoing the useless clutter I've created would be greatly appreciated.
        • 1. Re: Available Conditional Build Tag Expressions
          RoboColum(n) Level 5
          Hi raynerts and welcome to the RH community. Where exactly do the build tags remain? In the topics? In the Conditional Build Tags folder? If the later, open up your project's rhbuildtag.apj file in notepad - take a backup first - and remove the tags there.
          • 2. Re: Available Conditional Build Tag Expressions
            raynerts Level 1
            Hi Colum, thanks for your response.
            The file you directed me to has in it the tags we use throughout our project - which is cool - but the problem I'm having isn't with the tags that are defined in the "Conditional Build Tags" folder in the Project Manager, it's with items in the "Conditional Build Tag Expression" drop-down when you preview a topic.
            Let me try restating my problem... hopefully that will make the issue clear:
            I select a topic, I then view the selected topic using the glasses icon (CTRL+W), then at the top of the new window that's displaying my topic is a drop-down menu. This drop-down menu allows me to choose the conditional build tag expressions I want to filter the content displayed. For example, one of the choices is "NOT Tag_A AND NOT Tag_B" which excludes anything marked with Tag_A and Tag_B. The problem is, in that drop-down, I now have like 20 choices of expressions. Before I started experimenting with the various expressions (by clicking the "Define" button to the right of the drop-down), there were only 6 choices. And I'd like to get it back to the original 6 choices.
            I didn't add any new tags, I just created new combinations of ways to preview the content using those existing tags.
            Does that explain my problem any better?
            Thanks!
            • 3. Re: Available Conditional Build Tag Expressions
              Colum
              I chanced upon this because I seem to have the other problem you alluded to in your response. I wish to temporarily hide the tagging of text from my project, and the menu command which normally does this: View/Show, then uncheck the conditional areas check box fails to do this. Any suggestions. Does 6 have a way of protecting Tags?
              • 4. Re: Available Conditional Build Tag Expressions
                Indeed it does raynerts. If you select one of the build expressions in the topic preview, click on the "Define" button and exclude the tag from the output. Click OK and it disappears. You'll need to repeat this for each one.
                • 5. Re: Available Conditional Build Tag Expressions
                  Hi RValk. There is no way to hide a build tag from a project or the menu item to apply/remove them. If you remove a build tag from a project, it also removes all references to it in the topics. Is that what you meant?
                  • 6. Re: Available Conditional Build Tag Expressions
                    raynerts Level 1
                    Okay, we're almost there, Colum. The process you describe is exactly what I was doing before I posted to this forum. However, after defining a bunch of expressions to see how they changed the appearance of the content, they became part of that drop-down menu. I don't want them to be part of the drop-down menu... they were just experiments. And now they're crowding out the real expressions the rest of my team uses.
                    • 7. Re: Available Conditional Build Tag Expressions
                      Sorry I may not have been clear - not for the first time! If you go into this dialog and remove the tag from the "exclude" column, the "NOT xxxx" tag is removed from the drop down list. Does this explain things better?
                      • 8. Re: Available Conditional Build Tag Expressions
                        Hi all
                        Hopefully Colum will pardon my intrusion into the thread. I believe the expressions that are created are added to the ProjectName.PSS file. One easy way to get at this is to right-click any topic, choose Topic Properties, then the File tab. Now click the Open Folder button. Bingo! You are now in the general area. If your topic is inside a folder, you may need to navigate up the tree once or twice to the root of it. There you should find the PSS file.
                        Edit the PSS file using Windows Notepad. My expressions were added at the bottom of the file.
                        Cheers all... Rick
                        • 9. Re: Available Conditional Build Tag Expressions
                          Level 1
                          Hi Colum
                          Not quite. I just want to stop showing the tag in the WYSIWIG view. Not to remove text or remove the tag, but make it more readable while I regvise the topic. The finctionality was in RH5, and the menu option has not changed, so I'm puzzled.
                          Robin
                          • 10. Re: Available Conditional Build Tag Expressions
                            Hi Robin. You seem to be referring to the cross hatch that appears over text that has a build tag applied to it. Right? You can amend the colour of this cross hatch to be the same as your background. Go into your build tag folder and edit the properties.
                            • 11. Re: Available Conditional Build Tag Expressions
                              Level 1
                              Hi Colum
                              That's an elegant solution indeed - I'll modify it so it's there but way less obtrusive. Gives me the best of both worlds, and I am very grateful.
                              Robin
                              • 12. Re: Available Conditional Build Tag Expressions
                                raynerts Level 1
                                quote:
                                Originally posted by: Captiv8r
                                Hi all
                                Cheers all... Rick
                                Brilliant!
                                That's where those nasty guys were hiding. Now I can play around with the tag expressions without worry.
                                Out of curiousity though, where are all of the other expressions listed in that drop-down hiding? The PSS file only housed the ones I had added.
                                • 13. Re: Available Conditional Build Tag Expressions
                                  There are no build expressions added to a project by default. There are two build tags added by default to the RHBUILDTAG.APJ file. Only when you define the expression is the entry added to the project's PSS file.
                                  • 14. Re: Available Conditional Build Tag Expressions
                                    Fenway21117
                                    This has been an unsolved problem for years. I never got a solution and am just coming back to RoboHelp, sadly. My first disappointment reopening the project was selecting preview and seeing all the conditional build tag expressions. I too had experimented with the boolean until getting the desired mix. Now I too have many unused and unwanted conditional build tag expressions in the Preview pull down menu. I do not know how to delete them. They are not listed in the PSS file and are thus not Global Build Tag expressions. They are some kind of Prevew Build Tag expressions. The only other file that is updated is the CPD file, but that is a coded file and not editable with notepad.
                                    • 15. Re: Available Conditional Build Tag Expressions
                                      RoboWizard Level 4
                                      Hi Fenway21117 and welcome to our community
                                      You might try closing RoboHelp, renaming the .CPD, then restarting RoboHelp. It should re-create a new .CPD file as a result.
                                      Give that a go and let us know how it turns out.
                                      Cheers... Rick
                                      • 16. Re: Available Conditional Build Tag Expressions
                                        Fenway21117 Level 1
                                        Well, Mr. Wizard,
                                        renaming the .CPD file does work, like driving your car off a cliff onto rocks below. All the Preview Conditional Build Tag Expressions are gone, even the ones i wanted.
                                        • 17. Re: Available Conditional Build Tag Expressions
                                          RoboWizard Level 4
                                          Hi again
                                          As long as you simply renamed the .CPD, you should be able to reverse the process. Then note the expressions you actually want to keep. Then repeat the process again. You might wish to create a new layout, then select and use the expressions you want to keep first. I'm thinking this may force an update to the PSS file and maybe recursively propagate the desired build expressions back into the new .CPD.
                                          Cheers... Rick
                                          • 18. Re: Available Conditional Build Tag Expressions
                                            Fenway21117 Level 1
                                            It seems i now have a corrupted project file. I will have to start over again with a safe copy. This suggestion of yours will probably work, but it will be time consuming and difficult especially if the project keeps crashing. How much better it would be if there were just a simple mouse click to delete unwanted Preview Conditional Tag Expressions.
                                            • 19. Re: Available Conditional Build Tag Expressions
                                              RoboWizard Level 4
                                              Hi again
                                              Indeed I couldn't agree more. If you (and others) would like to put this request in front of the eyes that can make a difference, Click here and complete the form you should find there.
                                              Cheers... Rick
                                              • 20. Re: Available Conditional Build Tag Expressions
                                                marjoriem Level 1
                                                quote:
                                                Hi Colum,
                                                Thanks for the idea! I tried this today. Unfortunately, I liked it only up to a point. If I only apply one conditional build tag to my text, this works beautifully. However, if I apply multiple build tags to the same text, then the black cross-hatch (AKA "hash marks") that indicate that "there are mulitple build tags here" will still appear over my text.
                                                ~Sigh.~ It was a great idea, but for me, in almost all of the places where I apply build tags, I will apply more than one to any given text.
                                                Marjorie
                                                • 21. Re: Available Conditional Build Tag Expressions
                                                  Just Mary
                                                  Deleting entries from the "Global Build Tag Expressions" section of the PSS file, and then deleting the CPD file, do not get rid of the build expressions when I reopen the project and preview a file.... Anyone have any other ideas of how to get rid of them? I don't have MS Access, so I can't open the CPD file and edit any database entries.
                                                  • 22. Re: Available Conditional Build Tag Expressions
                                                    You can delete the PSS file. (Make a backup of your project first but it shouldn't be necessary). If you delete that and the CPD, which also rebuilds, I have found the expressions are trashed reliably.
                                                    If you are using a version earlier than RH7, look at Opening Projects on my site. Earlier versions may lose some information that is easily rebuilt.
                                                    • 23. Re: Available Conditional Build Tag Expressions
                                                      Just Mary Level 1
                                                      Nope, I deleted both, and the expressions are still there in the preview window, even though neither the new nor the old PSS and CPD files have any mention of them. (I found someone with a copy of Access and was able to look through the tables.) I'd made sure to delete the .bak files too, and I even rebooted my machine to be superstitious. I'm using RH 7.00.145 on Windows XP.
                                                      So I'm guessing this info. must stored somewhere else, too.
                                                      • 24. Re: Available Conditional Build Tag Expressions
                                                        We are talking about the build expressions and not the conditional tags in Project Manager?
                                                        • 25. Re: Available Conditional Build Tag Expressions
                                                          Just Mary Level 1
                                                          Yes, the items in the "Conditional Build Tag Expression" list in the topic preview window. The expressions I'd previously defined will not go away.
                                                          • 26. Re: Available Conditional Build Tag Expressions
                                                            When you generate the help, are the expressions also showing in the dropdown there. Sorry to be labouring this but the solution has worked for everyone else so it is difficult to understand what is going wrong here.
                                                            Also are you using version control and could that be pulling something in?
                                                            • 27. Re: Available Conditional Build Tag Expressions
                                                              Just Mary Level 1
                                                              Yes, the same expressions are available when I go to generate a build from one of the layouts. I'm not using version control, so I'm not sure what could be happening....
                                                              • 28. Re: Available Conditional Build Tag Expressions
        Just Mary Level 1
        Oh, I see -- an expression that is saved as part of a single source layout can't be removed from the expressions available for the topic preview. I'm not sure that that's how I necessarily want it to work, but it makes sense now at least.
        • 29. Re: Available Conditional Build Tag Expressions
        Deleting the PSS and the CPD should have removed them from both locations. Can you please clarify what happens after deleting the PSS and CPD?
        Are you still seeing them in layouts?
        Are you still seeing them in topic preview?
        • 30. Re: Available Conditional Build Tag Expressions
        Just Mary Level 1
        Deleting the PSS and CDP file deleted all build tag expressions that I had manually created in Preview mode. However, the build tag expressions that are part of a build tag (such as WebHelp, Printed Documentation, and so on) are still listed in Preview. I'm assuming Adobe figures that you'll want to be able to preview topics using the expressions that are applicable to your output, so when you save a build tag with specific expressions, the expression is added to the list automatically (thereby saving you the trouble of doing it manually).
        The build tag configurations are saved in files called <build tag>.ssl, so they are not deleted when you delete the PSS and CDP file.
        • 31. Re: Available Conditional Build Tag Expressions
        Apologies. There is one additional step that I had forgotten. You have to go to the layouts, right click and select Properties and then set the Build Expression to None.
        If you do that and Save, then there are no expressions in the layouts and they all get deleted.
        If you don't do that, an SSL might have several expressions listed before you delete the PSS / CPD and afterwards it will just have whichever one was selected in the layout at the time.
