1. Re: Why wont after effects render my whole movie ?
Pierre Devereux May 28, 2013 4:31 AM (in response to Kamii Akbari)Hi,
Can you please send us screen shots of your render settings as well, without that, it will be hard to guess what is causing the problem.
Pierre
2. Re: Why wont after effects render my whole movie ?
Rick Gerard May 28, 2013 4:54 AM (in response to Kamii Akbari)most likely problem is that you have not properly setup your Render Settings. That's where you set the length of the render. The default is to render the length of the work area. Your comp's work area is probably not set to cover the entire composition.
You cannot just open AE and start using it. You must learn how the program works. Please go through the getting started materials you'll find here.
3. Re: Why wont after effects render my whole movie ?
Kamii Akbari May 28, 2013 7:59 AM (in response to Pierre Devereux) -
4. Re: Why wont after effects render my whole movie ?
Kamii Akbari May 28, 2013 9:56 AM (in response to Rick Gerard)I did see no help. I think it is a in system problem, with the render settings. Which may be change by a mistake. If you see the replies you can see my Render settings.
5. Re: Why wont after effects render my whole movie ?
Pierre Devereux May 28, 2013 10:54 AM (in response to Kamii Akbari)Hi,
Can we see a screenshot of your project and timeline as well maybe?
Pierre
6. Re: Why wont after effects render my whole movie ?
Kamii Akbari May 28, 2013 11:18 AM (in response to Pierre Devereux)I did just replied a screen shot.
7. Re: Why wont after effects render my whole movie ?
andi_urra May 28, 2013 2:05 PM (in response to Kamii Akbari)Hi, according to you screenshot you should get 45 seconds and 17 frames. Either way, you should set the "time span" field to "length of comp". Also check to frame rate.
